how to capture events for next item
Ashish
In outlook 2003, When open a mail there are 2 buttons in statndard menu
which are Next Item and Previous Item (in arrow symbol) in open mail window.
I am not able to capture events for these two buttons. Besides these i can
capture events for other buttons on standard menu. I can not know in my
addin when user click on these buttons. Their ids are 359 and 360.Please
suggest how to capture events for those.
H
Heinz-Josef Bomanns
Hallo Ashish,
You can try to put references to the two buttons for e.g. in variables
(declared 'As Office.CommandbarButton') "btnID359" and "btnID360",
then hide the buttons (.Visible= False) and add your own buttons with
the same positions and FaceIDs. In the appropriated event procs of
your buttons do what you have to do and finally do call
"btnID359.Execute" or "btnID360.Execute" to run the original
functionallity. Just some theoretical thoughts, but worth a try i
think...
So long...
> ..Bomi
> !!! In case you want to reply via email please use Reply-To address and remove underscores (_) !!!
Ashish
Thanks for this info.
Does it mean it is not possible to capture events for these buttons. Outlook
does not provide that?
"Heinz-Josef Bomanns" <NotForMail@t-online.de> wrote in message
news:lrfne5dgnsanoutcnebq322n2temkg52q2@4ax.com...
> Hallo Ashish,
> >window.
> think...
> So long...
> ...Bomi
K
Ken Slovak - [MVP - Outlook]
The problem is you are handling events for a specific
Inspector.CommandBars.CommandBarButton object. Clicking Next or Previous
will open a new Inspector in Outlook 2003.
Why do you need to handle events for those specific button clicks?
"Ashish" <akohli_2004@hotmail.com> wrote in message
news:%230ag9piWKHA.3720@TK2MSFTNGP02.phx.gbl...
> Outlook does not provide that?
Ashish
Oh it means when we click on nexe/previous item a new inspector open.
Because when we click on next/previous button outlook first call
onnewinspector while another inspector is not close. After this outlook call
close inspector for another inspector. And the main problem is outlook never
call item_open event for new inspector.
news:%23Mn3AN0WKHA.1268@TK2MSFTNGP04.phx.gbl...
H
Heinz-Josef Bomanns
Hallo Ashish,
Yes...
> > Hallo Ashish,
> >>window.
> > think...
So long...
> ..Bomi
Ashish
How outlook calls its event when i open a mail and close it
open a mail, outlook call onnewinspector. In this i get
inspector.currentitem and registered events for current item.
Then outlook call item_open event, i add a attachment in current item but do
not call item->Save. Now when mail display it shows an attachment. After
this when i close this mail outlook call item_close. Here i delete that
attachment and call save function. After this outlook call inspector_close.
Now for the case when i click on next/previous item
not call item->Save. Now when mail display it shows an attachment. When i
click on next button outlook call inspector_close (here it did not call
item_close). Then it call onnewinspector for next mail. After that outlook
call item_close for previous mail. And outlook does not call item_open for
next mail.
I have 2 problems here.
1. For next mail since i do not get item_open event so can not add a
attachment in next mail.
2. Since for this case outlook calls inspector_close event (did not call
item_close event and i add a attachment in mail, means i modify the mail )
so outlook prompts a message "Do you want to save".
Since item_close is not called, In inspector_close i delete attachment from
mail and save it but still outlook displays the message "Do you want to
save".
Thats why i ask how to register events for next/previous button. But since
it's not possible so is there any solution for that problem.
K
I don't really see a solution since you are changing items without saving
them. That will force the prompts. We've gone over various other problems
caused by this structure, about all I can think of other than not adding the
attachments or saving the items is to disable those buttons so they can't be
used.
news:emzFS%237WKHA.4704@TK2MSFTNGP02.phx.gbl...
> do not call item->Save. Now when mail display it shows an attachment.
> After this when i close this mail outlook call item_close. Here i delete
> that attachment and call save function. After this outlook call
> inspector_close.
> do not call item->Save. Now when mail display it shows an attachment. When
> i click on next button outlook call inspector_close (here it did not call
> outlook call item_close for previous mail. And outlook does not call
> item_open for next mail.
> from mail and save it but still outlook displays the message "Do you want
> to save".
Ashish
Previous and next button and popup button. Under Previous/Next button there
are many control buttons. We can capture event for these control buttons not
for these popup button.
Does outlook not support to capture event for a popup button when it's
clicked.
news:uUyazr8WKHA.844@TK2MSFTNGP05.phx.gbl...
> the attachments or saving the items is to disable those buttons so they
> can't be used.
> > inspector_close.
> > When i click on next button outlook call inspector_close (here it did not
> > call item_close). Then it call onnewinspector for next mail. After that
> > mail ) so outlook prompts a message "Do you want to save".
> > to save".
> > since it's not possible so is there any solution for that problem.
K
There are a number of different commandbar controls that MS uses that
outside programmers can't get at or use ourselves. As I said, I don't see a
solution to get those clicks.
news:efsgTnhXKHA.4068@TK2MSFTNGP06.phx.gbl...
> there are many control buttons. We can capture event for these control
> buttons not for these popup button.
> clicked.
Sanadeep Yadav
Hi Ashish,
I also had similar problem .. here is the solution which u got after 2 days
RnD :)
include Ribbon xml file : (You will need to customize qat)
<ribbon startFromScratch="true"
<qat
<sharedControls
<button idMso="FileSave" /
<button id="PreviousAction" label="Previous"
supertip="Click to view previous email message"
imageMso="MessagePrevious"
onAction="Previous_Action" keytip="C" /
<button id="NextAction" label="Next"
supertip="Click to view next email message"
imageMso="MessageNext"
onAction="Next_Action" keytip="B" /
</sharedControls
</qat
</ribbon
Next_Action()
// do your action
//Call following to use default feature of Next arrow
Globals.ThisAddIn.Application.ActiveInspector().CommandBars.ExecuteMso("MessageNext");
same goes for previous action ..
Regards,
Sandeep Yadav
> .Net Developer
"Heinz-Josef Bomanns" wrote:
> Hallo Ashish,
> Yes...
> >> Hallo Ashish,
> >>>window.
> >> think...
> So long...
> ...Bomi
A how to capture outlook 2007 events Outlook VBA and Custom Forms 4
R Capture Sender's Display name and Address Outlook VBA and Custom Forms 3
I Capture incoming emails Outlook VBA and Custom Forms 1
A Capture network traffic in IE to file Outlook VBA and Custom Forms 5
JorgeDario How to capture and save the text, when responding a MailItem? Outlook VBA and Custom Forms 3
G Capture "forward event" ? Outlook VBA and Custom Forms 11
J VBA Form in Outlook to capture data and complile a mail Outlook VBA and Custom Forms 2
B Capture Inbound E-mail Subject with VBA Outlook VBA and Custom Forms 4
R How to capture a Mailitem Event Outlook VBA and Custom Forms 3
T Some way to capture who marks an email as read Outlook VBA and Custom Forms 1
C Event Capture - Item Context Menu (Delete). Can you hook it? Outlook VBA and Custom Forms 1
O After filtering, how to display all events on that day? Using Outlook 4
O Carriage Return - Line Feeds - exporting Calendar events Using Outlook 0
A Outlook Reminders not populating for certain events Using Outlook 2
J Outlook Office 365 Win 10 how do I control background colors of events? Using Outlook 1
G Outlook VBA and Google Calendar ("Events") Outlook VBA and Custom Forms 1
P Outlook custom fields "events" Using Outlook 0
U Catching ModuleSwitch events after "open in new window" Outlook VBA and Custom Forms 2
T Categorizing different colors for a series of events Using Outlook 0
oliv- property "is printed" or catching print events Outlook VBA and Custom Forms 2
P Outlook 2013 Calendar events not appear on Outlook.com Calendar Using Outlook.com accounts in Outlook 6
V iCloud not syncing categorized calendar events Using Outlook 7
W All Events Disappear from Calendar Display Using Outlook 30
I Multiple events in single request Using Outlook 6
T Events Not Showing In Outlook Today Using Outlook 3
J Calendar view for future events only? Using Outlook 3
G Hiding All Day Events Using Outlook 1
microsvc Populating everyone's calendar with campus events Exchange Server Administration 1
Dave Godbey Sending Categories on Calendar Events Using Outlook 1
C Problem accessing events for folder "username" Server Threw Exception Using Outlook 1
S Syncing Past events from Outlook 2013 to Outlook.com Using Outlook.com accounts in Outlook 6
F Printing all day events only Using Outlook 3
E Outlook 2013 , iCloud linked calendar, events one hour ahead for about a month Using Outlook 5
B Timed events created in iPhone auto-change to All Day events in Outlook 2010 Using Outlook 2
H Events in Calendar not Bold Using Outlook 1
S Outlook - Reset the number of day-events Using Outlook 0
B Series of calendar events? Or Tasks? Using Outlook 1
D All New Appointments are All Day Events Using Outlook 1
P Printing calendar (work week) with numerous (i.e. >7) all day events... Using Outlook 3
A Outlook CPAO - Printing Monthly calendar with only all day events or catergory Using Outlook 2
S Full-day events Using Outlook 1
T Changing default reminder time for all day events - additional help needed Using Outlook 1
