Outlook 2003 macro security problem
  • Thread starter Thread starter John Blessing
John Blessing
Using Outlook 2003, SP3
I have an extensive set of Outlook macros which have been working fine for
quite some time, no recent changes. Now Outlook hangs when I open it.
I have:
deleted outcmd.dat - no joy
deleted vbaproject.otm - works OK
opened in safe mode - works OK
The only thing that seems to work and still allow macros is to set macro
security to low.
I have deleted all personal certificates and recreated one using selfcert,
but even if I sign the macro code with it, setting security back to High
causes the same problem.
Any ideas?
John Blessing
If it works in safe mode, then try turning off other add-ins besides VBA.
Sue Mosher
"John Blessing" <nospam.lbe@REMOVE_THISgmail.com> wrote in message
news:4b1cdbfc$0$2478$db0fefd9@news.zen.co.uk...
> Hi
> I have:
> security to low.
> Any ideas?
> > John Blessing
Forgot to mention, no other add-ins
John
> VBA.
> > Hi
> > fine for quite some time, no recent changes. Now Outlook hangs when
> > I open it. I have:
> > macro security to low.
> > selfcert, but even if I sign the macro code with it, setting
> > security back to High causes the same problem.
>> Any ideas?
>> > > John Blessing
What about Exchange client extensions? Add-ins hidden from the Add-ins
dialog?
Also, there are several "flavors" of safe mode you can use to try to
pointpoint the problem: http://www.outlook-tips.net/beginner/safemode.htm
Sue Mosher
news:4b1d23a8$0$2522$da0feed9@news.zen.co.uk...
> John
> > VBA.
> >> Hi
> >> I open it. I have:
>>> Any ideas?
>>> > >> John Blessing
No COM add-ins, no anti-virus integration. safe:2/3/4 make no difference
There is an "Exchange extensions property pages" listed in the Add-ins
manager, but it is unticked. The only one ticked is Windows CE Support and
unticking it doesn't solve the problem.
If I change security to High then it hangs.
To fix it I have to delete the existing vbaproject.otm, open Outlook, set
security back to low, then put back a copy of my vbaproject.otm
I am pretty sure it is something to do with the certificate.
John
> dialog?
>> John
> >> VBA.
> >>> Hi
> >>> when I open it. I have:
>>>> Any ideas?
>>>> > >>> John Blessing
John Blessing
http://www.LbeHelpdesk.com - Help Desk software
http://www.room-booking-software.com - Schedule rooms & equipment
bookings http://www.lbetoolbox.com - De-Duplicates MS Outlook
http://www.repeatmail.com - schedule mass individual emails
Sorry, but I have no ideas on what to do about that.
Sue Mosher
news:4b1d2ff4$0$2525$da0feed9@news.zen.co.uk...
> John
> > dialog?
>>> John
> >>> VBA.
> >>>> Hi
>>>>> Any ideas?
>>>>> > >>>> John Blessing
> > John Blessing
Ok, thanks for trying
John
> > difference There is an "Exchange extensions property pages" listed in
> > the
> > Add-ins manager, but it is unticked. The only one ticked is Windows
> > CE Support and unticking it doesn't solve the problem.
> > Outlook, set security back to low, then put back a copy of my
> > vbaproject.otm I am pretty sure it is something to do with the
> > certificate.
>> John
> >> Add-ins dialog?
>>>> John
> >>>> besides VBA.
> >>>>> Hi
> >>>>> set macro security to low.
>>>>>> Any ideas?
>>>>>> > >>>>> John Blessing
>> > > John Blessing
John Blessing
D outlook 2003/2007 macro query Using Outlook 2
F Creating Macro in Outlook 2003 Using Outlook 8
D Outlook 2003 stopped dead Using Outlook 2
D Wishlist How to use 'app password' in Outlook 2003 after Google pulled plug on "less secure apps" Using Outlook 2
