SBS 2003 to serve mix of Outlook versions
  • Thread starter Thread starter NitinS
N
NitinS
We run SBS 2003 R2. We use OL 2003 on 3 clients. We use several VBA
macros/code to interface with Exhange Public folders, Word & Excel.
The VBA*.otm is placed in each of the clients local roaming directories.
We need to try out OL 2007 and OL 2010 in 2 new machines that will use the
same SBS 2003 box & Exchange Public folders.
Trouble is the VBA code referances Word, Excel, Outlook 11 libraries. For
the OL2007 we need to referance the ver 12 libraries which will render the
VBA porjects unusable with Ol 2003.
Can soemone suggest a fairly simple & usable solution?
VBA code is not intended for deployment. It is for personal macros and for
prototyping. Use COM addins instead.
"NitinS" <NitinS> wrote in message
news:8DDA5EE5-342D-4492-9BE3-3C7A9418C6B7@microsoft.com...
S Public FolderEmail Sort Problems Outlook 2010/Migration from 2003 SBS to 2011S Using Outlook 3
T Install BCM on SBS 2008 Standard server BCM (Business Contact Manager) 1
A BCM 2007 Shared Database on member Server 2008 in SBS 2008 Domain BCM (Business Contact Manager) 1
Z Integration BCM SBS 2008 BCM (Business Contact Manager) 6
D Outlook 2003 stopped dead Using Outlook 2
D Wishlist How to use 'app password' in Outlook 2003 after Google pulled plug on "less secure apps" Using Outlook 2
B 2013 to 2003 Exchange Server Administration 0
C 2003 OL to OneDrive People Using Outlook 1
J Using 2003 .pst files w 2013 Using Outlook 1
M Can't open .pst file in Office 2003. Using Outlook 2
B Exchange 2003 EDB corrupt Exchange Server Administration 6
C Can't open .pst file in Office 2003 Using Outlook 1
P Macros in Word 2003 - how to transfer to another Word 2003? Using Outlook 1
