recurring meeting exceptions count not updated
  • Thread starter Thread starter GR
G
GR
I am having a problem getting an accurate result from reading the
number of exceptions to a recurring meeting when that appointment item
is in a shared folder.
Specifically, after I delete an instance of a recurring meeting, my
code is called in the calendar ItemChange event for that calendar and
I then call a sub that reads the number of exceptions for that
appointment item that just had an instance deleted.
When I look at the number of exceptions for that item it is properly
incremented by 1 each time I delete an instance of a recurring
appointment that is in my default calendar folder, UNLESS, that
appointment item is on a shared calendar. In that case, it is set to 1
exception (correct) the first time but will not increment for each
subsequent deletion unless I close Outlook and re-open it.
It almost seems as though I need to refresh the exception list somehow
before checking? Any ideas?
Here is a code snippet that I am using:
Dim excepts As Outlook.Exceptions
Dim anExcep As Outlook.Exception
Dim nExceptions As Integer
Shared folders can be strange for updating. Implement the idea you had of
refreshing Exceptions and the RecurrencePattern.
"GR" <gprourke@gmail.com> wrote in message
news:86b234a8-e494-4ec0-97d7-e449b7433335@i25g2000yqm.googlegroups.com...
> Hello,
> Set excepts = inMasterAppt.GetRecurrencePattern().Exceptions
> nExceptions = excepts.Count
> Thanks!
On Mar 26, 1:28 pm, "
> http://www.slovaktech.com
> "GR" <gprou...@gmail.com> wrote in message
> > Hello,
> > Thanks!-
I believe you're right about shared folders updating.
What would you recommend is the best way to refresh the Exceptions and
RecurrencePattern? There isn't any type of "refresh" method to either
of those objects I don't believe. Right?
Release your references to the item/series/pattern/etc. and use the EntryID
from the master to get it again and re-instantiate everything.
news:f7abf9f2-921a-4b53-8027-efc914761df9@o30g2000yqb.googlegroups.com...
<snip
P Receiving a Meeting Declined notice for a recurring meeting Using Outlook 0
G how to cancel a recurring meeting but not the organizer but all attendees need to know. Using Outlook 1
L Who Deleted My Recurring Meeting? Exchange Server Administration 6
F Recurring meeting with recurring prep. 2 days before Using Outlook 1
J Recurring meeting - i require a monthly accept confrimation Using Outlook 1
M Recurring invitations for a recurring meeting Using Outlook 3
M Email address included automatically in the recurring meeting Using Outlook 4
L Setting up recurring meeting for every thursday except 3rd thursday Using Outlook 3
D Updating a recurring meeting cuses a reminder to be sent for every occurence. Using Outlook 2
P Delete Recurring Meeting Invite Using Outlook 4
A Recurring meeting sending a invite for each meeting Using Outlook 1
R How do I cancel future occurences of recurring meeting in outlook Using Outlook 6
B change meeting organizer of recurring meeting without cancellnig Using Outlook 2
S Outlook 2016 Understand and customize prepended behavior of recurring task Using Outlook 0
J Recurrence pattern blank on recurring meetings? Using Outlook 4
V Outlook 2016 Multiple recurring tasks getting created Using Outlook 0
K Recurring all day annual event Using Outlook 3
P Restore an individual all-day recurring event Using Outlook 2
F Year-and-a-day recurring appointments Using Outlook 1
C Recurring Task End Date Varies Using Outlook 3
M Expected behaviour of recurring appointments? Using Outlook 2
K Outlook 2013 Recurring Tasks Not Showing Complete Outlook.com Using Outlook.com accounts in Outlook 1
L Recurring Tasks lost Using Outlook 3
M Recurring icon for custom form task item Outlook VBA and Custom Forms 6
Diane Poremsky Scheduling a Recurring Message Using Outlook 0
T outlook cal for mac changes times of recurring meetings on its own Using Outlook 1
T The Formatting Changes When A Recurring Appointment is Changed Using Outlook 1
S Modify recurring outlook invites based on form entry Using Outlook 0
S How to script for a recurring task Using Outlook 0
I VBA Recurring Task Converted From Email Using Outlook 2
M outlook recurring item stucks me. :( Exchange Server Administration 1
M How to skip weekends on recurring appointments - OL2010? Using Outlook 4
D Priting only Recurring Appointments in Outlook Calendar 2010 Using Outlook 1
X Can you get outlook to ignore certain weeks for recurring meetings? Using Outlook 1
B weekday recurring appointments Using Outlook 1
J Recurring Appointments With A Twist Using Outlook 3
G Weekly recurring appointments based on 6 month rotation Using Outlook 2
D Recurring Tasks Problem? Using Outlook 5
B Restoring Deleted Recurring Event AND Notes Using Outlook 8
O Assigning a single instance of a recurring task OUTLOOK 2010 Using Outlook 3
F Outlook 2007 - recurring appointments shifted by one day Using Outlook 4
H skip one ocurrence appointment from recurring appointment series Outlook VBA and Custom Forms 5
J Get Dates of Recurring Events in Shared Appointment Calendar Outlook VBA and Custom Forms 4
