Recurring Tasks Problem?
djulian
First post; spent a lot of time searching the forums and Google, etc--could not find a solution that works.
My problem:
I use Outlook 2007, with my gmail set for IMAP
I have designed a custom form for my tasks, which includes several User-defined fields
I create a task that recurs every weekday (e.g., "Walk with wife")
I click to complete the task and I get the "Could not complete the operation. One or more parameters are invalid." error message in the bottom right corner.
If I remove the recurrence, I can complete these tasks without a problem. This only happens with recurring tasks. I've tried all of the Microsoft recommended solutions short of reinstalling Outlook and reentering all of my information.
So, questions:
1) Is this because I use custom fields?
2) Is there a fix that doesn't require reinstall/reentry?
I'd like to keep the ability to enter recurring tasks, but I don't know if I'm willing to go through all that rigamarole for the few (5-10) recurring tasks that I have.
Thank you all!
1. It shouldn't be due to the custom fields, but I'll need to test it to be sure.
2. Reinstall of Outlook shouldn't be necessary but if we can figure out why its happening, you might need to redo the form or republish it.
Did you try deleting the forms cache and restarting outlook?
Can you forward me a task as an attachment so i can test it? My quickie tests worked as expected... try attaching it to a message using Insert, Item and send it to diane at slipstick
Hi Diane!
Thank you for the rapid response; I just tried clearing the forms cache and that didn't help. I'll send the task in a message in just a moment.
I got them - they work correctly here but i don't see the custom fields - that's not unusual and usually means nothing. I was hoping that forwarding it included the custom fields as Outlook can make it difficult to send custom forms.
What type of custom fields did you add - basic fields or formulas that got data from other fields?
Hi Diane!
They're basic fields that provide a combo-box with several pre-added options (though you can type your own in). No formulas. There is one that operates off of a "Yes/No" checkbox. Perhaps that's the issue? I've attached a picture of the tab with the added fields for the custom form. The "Big Rock" box uses the "yes/no" option.
Thanks! :)
V Outlook 2016 Multiple recurring tasks getting created Using Outlook 0
K Outlook 2013 Recurring Tasks Not Showing Complete Outlook.com Using Outlook.com accounts in Outlook 1
L Recurring Tasks lost Using Outlook 3
S Outlook 2016 Understand and customize prepended behavior of recurring task Using Outlook 0
J Recurrence pattern blank on recurring meetings? Using Outlook 4
K Recurring all day annual event Using Outlook 3
P Restore an individual all-day recurring event Using Outlook 2
F Year-and-a-day recurring appointments Using Outlook 1
P Receiving a Meeting Declined notice for a recurring meeting Using Outlook 0
C Recurring Task End Date Varies Using Outlook 3
M Expected behaviour of recurring appointments? Using Outlook 2
G how to cancel a recurring meeting but not the organizer but all attendees need to know. Using Outlook 1
M Recurring icon for custom form task item Outlook VBA and Custom Forms 6
Diane Poremsky Scheduling a Recurring Message Using Outlook 0
L Who Deleted My Recurring Meeting? Exchange Server Administration 6
T outlook cal for mac changes times of recurring meetings on its own Using Outlook 1
F Recurring meeting with recurring prep. 2 days before Using Outlook 1
J Recurring meeting - i require a monthly accept confrimation Using Outlook 1
T The Formatting Changes When A Recurring Appointment is Changed Using Outlook 1
S Modify recurring outlook invites based on form entry Using Outlook 0
S How to script for a recurring task Using Outlook 0
I VBA Recurring Task Converted From Email Using Outlook 2
M Recurring invitations for a recurring meeting Using Outlook 3
M outlook recurring item stucks me. :( Exchange Server Administration 1
M Email address included automatically in the recurring meeting Using Outlook 4
L Setting up recurring meeting for every thursday except 3rd thursday Using Outlook 3
M How to skip weekends on recurring appointments - OL2010? Using Outlook 4
D Priting only Recurring Appointments in Outlook Calendar 2010 Using Outlook 1
X Can you get outlook to ignore certain weeks for recurring meetings? Using Outlook 1
D Updating a recurring meeting cuses a reminder to be sent for every occurence. Using Outlook 2
B weekday recurring appointments Using Outlook 1
J Recurring Appointments With A Twist Using Outlook 3
P Delete Recurring Meeting Invite Using Outlook 4
A Recurring meeting sending a invite for each meeting Using Outlook 1
G Weekly recurring appointments based on 6 month rotation Using Outlook 2
B Restoring Deleted Recurring Event AND Notes Using Outlook 8
O Assigning a single instance of a recurring task OUTLOOK 2010 Using Outlook 3
F Outlook 2007 - recurring appointments shifted by one day Using Outlook 4
G recurring meeting exceptions count not updated Outlook VBA and Custom Forms 3
R How do I cancel future occurences of recurring meeting in outlook Using Outlook 6
H skip one ocurrence appointment from recurring appointment series Outlook VBA and Custom Forms 5
J Get Dates of Recurring Events in Shared Appointment Calendar Outlook VBA and Custom Forms 4
D Recurring Emails Using Outlook 4
