Shared addin using .net - deployment for non admins
  • Thread starter Thread starter TW9zaGUgTWFsaW4
TW9zaGUgTWFsaW4
My main target is to deploy a shared add-in (developped with .Net, for XP,
OL2003, 2007) to non-admin users.
We assume they already have the CLR.
We know that we can use HKCU instead of HKLM.
But: we cannot assume the PIA are already installed, and this is our main
problem.
Is there a way to deploy the PIA dlls without admin rights (MS PIA
installation puts it in the GAC and requiers admin right) ?
Can we use the PIA dlls locally (say, in the execuation directory), instead
of using it from the GAC?
Is there any alternative for PIA that does not require admin rights (like
making our own IA)?
Unless you control the deployment and provisioning of all those machines
it's not safe to assume that the Framework has been installed. It is not
installed for Office 2007 or any earlier version and only is there by
default for CD installations of Windows XP SP2 or higher, or for Vista.
It's really not recommended at all to deploy official PIA's to an
application specific folder, it will cause PIA hell. And if something else
deploys a PIA to the GAC that's where Fusion will look first, therefore
possibly forcing you code to run with a different or incompatible PIA. PIA's
like those from MS really need to be deployed to the GAC.
I'd also be careful with any PIA that is derived from the official PIA for
Outlook 2002, it has bugs and needs modifications to work correctly.
An alternative would be using a PIA-less solution but then you have to
specify the complete interfaces for everything the PIA would handle, so for
things as big as the Office and Outlook PIA's it would be a ton of work to
implement a PIA-less solution.
"Moshe Malin" <Moshe Malin> wrote in message
news:1CB755C3-B545-4C59-B52D-E15F5BC37290@microsoft.com...
> Hello,
> problem.
> instead
> making our own IA)?
> Thanks.
It means, actually, that there is no reasonable way to deploy add-in for non
admins.
Before going to C++ solution - is there any resource that can point to a way
that might achieve non-admin deployment?
I've tried searching the web, but failed to find such.
[About the .net framework, my assumption was that users without .net must
install it first, it's out of non-admin scope]
Installing the Framework also requires admin permissions you know.
If this is some sort of rollout then you can have admins install the
Framework and the PIA's as separate from the code installation. Language
choice makes no difference, the only difference would be if you used
unmanaged code in whatever language (C++, VB6, Delphi, etc.) and then you
don't need either the Framework or the PIA's.
"Moshe Malin" <MosheMalin> wrote in message
news:C046F0B3-EC80-4762-AC81-B65C6D2EBB51@microsoft.com...
> Thank you.
> non
> admins.
> way
S Rule on a shared mailbox only runs when my Outlook is open Using Outlook 5
K Who made changes to a shared contact Using Outlook 4
V Unchecking my calendar and leaving shared one visible Outlook VBA and Custom Forms 1
S Email Macros to go to a SHARED Outlook mailbox Draft folder...NOT my personal Outlook Draft folder Using Outlook 2
C Outlook 365 Multiple different Signatures on Shared Mailbox Using Outlook 0
Fozzie Bear Shared Calendar For Scheduled Tasks Using Outlook.com accounts in Outlook 3
J Outlook 365 Forward Email Subject to my inbox when new email arrive in shared inbox Using Outlook 0
J Hide/disable "Groups", "Shared Calendars" Using Outlook 2
T Never-ending Reminders in Shared Calendars Using Outlook 3
S Outlook 365 Shared mailbox contact group member numbers not matching Using Outlook 0
P Emails assigned with a certain category (within a shared inbox) to be copied to a specific folder. Outlook VBA and Custom Forms 2
peterbata Shared Tasks Outlook for Mac Using Outlook 5
N Having Shared Calendar shift to Current day Using Outlook 0
C Pull Outlook shared calendars items from Excel Outlook VBA and Custom Forms 4
M Outlook 365 Searching all shared calendars Outlook VBA and Custom Forms 4
S newly added shared mailboxes downloading 500GB data a day Exchange Server Administration 1
A New email notification on shared mailbox Outlook VBA and Custom Forms 0
N Shared mailbox in cached mode Using Outlook 0
S Import contacts to a shared mailbox Outlook VBA and Custom Forms 2
D Delete Emails from Senders in Shared Mailbox Outlook VBA and Custom Forms 1
E Accessing shared outlook folder doesn't work since switch to new outlook/excel Outlook VBA and Custom Forms 11
J Updating existing entry on shared calendar wants to send update from delegate Using Outlook 0
C Changed By field not displaying individual user's name in O365 Shared Mailbox Using Outlook 9
G Unable to dismiss reminders from share point list calendar shared in Outlook Using Outlook 2
M how to speed up search of shared contacts Using Outlook 0
S Recovering permanently deleted folder from shared mailbox Using Outlook 1
S How to extract mail items from multiple folders and shared mailboxes? Outlook VBA and Custom Forms 0
C Outlook Shared Calendar Using Outlook 1
N Does a Shared Folder Policy override a Digital Signature Setting for macros? Outlook VBA and Custom Forms 6
