Outlook 2010 and Multi-Part MIME Messages
Stoertebeker
Hi all,
we have a network printer capable of sending scanned documents as .pdf file to a user. If the mails get too large (more than ~16 pages) it splits the mail into several parts.
These parts were automatically reassembled into a single mail that contained the .pdf file as an attachment by our old Outlook2000 Client on WinXP. The original messages were moved to the trash.
After updating to Win7 / Outlook 2010 the mails are no longer assembled. Instead the individual parts are displayed (part x/y) and the mail text starts with the following header:
Subject:
To: "xyz" <xyz@yyy.de
Date: Wed, 8 Jun 2011 12:07:51 +0200
Message-Id: <201106081207456F.DCSML-S000210000.000074F20198@172.16.10.92
MIME-Version: 1.0
Content-Type: multipart/mixed;
boundary="DC_BOUND_PRE_<1307527663.000074f20198>"
This is a multi-part message in MIME format.
--DC_BOUND_PRE_<1307527663.000074f20198
Content-Type: text/plain; charset=ISO-8859-1
Content-Transfer-Encoding: quoted-printable
Content-Type: application/pdf; name="20110608120743085.pdf"
Content-Transfer-Encoding: base64
Content-Disposition: attachment;
filename="20110608120743085.pdf"
followed by base64-encoded data. I am neither automatically nor manually able to reassemble the attachment. Also saving the individual parts fails with a nonspecific error.
Can anyone help?
regards
Stoerte*
Outlook no longer includes file split/join capability - you'll need to use a utility such as this: http://download.cnet.com/File-Splitter-Utility/3000-2248_4-10397874.html. Search Bing for other file splitter and join utilities - there are a lot. That was just the first one i found - i don't think i ever used it (and haven't used one in years.)
Also, if you use a zip utility other than the compression tool included in windows, it might join the parts.
Now sure why you are getting en error when you save them - oh, is there a real attachment or just the text in the email body? You need to copy the text and paste into notepad and save it. It's been ages since i needed to do that so i forget the specifics... it would probably be easier to keep a computer (or virtual machine) with 2000 installed handy... <g>
BTW - Outlook Express and its replacement, the Live mail client, both support joining attachments - it might be easier to use one of those if you have imap access to the mailbox. (POP3 will work but if not configured right, will delete mail from the server.)
O How to display multi-line task in To-Do List - Outlook 2010 Using Outlook 1
S Outlook 2010/Exchange 2010 Multi Mailboxes (Server unavailable) Using Outlook 6
F Outlook 2010 and Hotmail Using Outlook 1
