Upgrade 2003 to 2010 and max pst file size of 2GB
blackbrook
I have upgraded to Outlook 2010 from 2003 and having trouble with the inherited max file size of 2GB. I have created a new pst file in 2010 selecting the new pst file type (not 97-2002), copied all my folders from the old pst file into the new one and still have the same problem of it will not go past 2GB.
J Upgrade from 2003 to 2007 Outlook VBA and Custom Forms 14
B Upgrade 2003 BCM to 2007 BCM BCM (Business Contact Manager) 3
T Custom form created in 2003 won't print since upgrade to 2007 Outlook VBA and Custom Forms 1
T Custom form created in 2003 won't print since upgrade to 2007 Outlook VBA and Custom Forms 13
T upgrade from outlook.com to Outlook Using Outlook 2
T How do I upgrade from outlook.com to Outlook? Using Outlook 5
M re-Attaching PSTs after upgrade to 2016 Using Outlook 0
M Upgrade in Progress. Your mailbox is currently being optimized as part of upgrade to Outlook 2010 Using Outlook 9
E Upgrade Issues - Office/Outlook 2007 to 2010 Using Outlook 0
Diane Poremsky How to Upgrade to Color Categories Using Outlook 0
P Outlook 2013 search broken after upgrade from 2010 Using Outlook 0
W Outlook 2013 - 2nd acct stopped receiving email after Win 8.1 upgrade Using Outlook 3
U BCM upgrade help BCM (Business Contact Manager) 0
F Which upgrade should I go for and how do I do it please? Using Outlook 2
H Outlook 2010 unable to send iCloud account e-mail after iOS 7 upgrade Using Outlook 12
B Two Inboxes after upgrade, how to merge? Using Outlook 4
L Outlook 2002-2013 upgrade Using Outlook 3
Horsepower Upgrade advice needed Using Outlook 3
T Outlook 2010 keeps asking password after upgrade Exchange Server Administration 1
S Upgrade Outlook 2007 to outlook with Buisiness Contact m|Manger BCM (Business Contact Manager) 2
E How to restore BCM Database after upgrade from Vista to Win7? BCM (Business Contact Manager) 1
B Upgrade to 2007, Action stopped working Outlook VBA and Custom Forms 3
A Upgrade to 2007, lost 'Accounts' info BCM (Business Contact Manager) 1
J BCM no longer loads sqlserver after SP2 upgrade BCM (Business Contact Manager) 2
D Outlook 2003 stopped dead Using Outlook 2
D Wishlist How to use 'app password' in Outlook 2003 after Google pulled plug on "less secure apps" Using Outlook 2
B 2013 to 2003 Exchange Server Administration 0
