BCM upgrade help
URE
Outlook 2013 32 bit
I am trying to upgrade from BCM 2007 to BCM 2013. I use a SQL 2008r2. I used the database tool to create a 2013 database and I need to migrate the contents of the 2007 database to the new one. what are the steps? do I need to upgrade the database to 2010 first?
E How to restore BCM Database after upgrade from Vista to Win7? BCM (Business Contact Manager) 1
B Upgrade 2003 BCM to 2007 BCM BCM (Business Contact Manager) 3
J BCM no longer loads sqlserver after SP2 upgrade BCM (Business Contact Manager) 2
