purge from in box
frank
when i delete from the in box i must purge to remove the email. i'm running xp windows outlook 2007
it use to work fine, had computer re-built.also i have one pop/smitp and three imap/smitp accounts,
how do i get them to come into the same folder (in-box). now they are coming into two different in-boxs,
i'm sure the setting have to be re-worked.....can someone give me the right settings
That is how it works with IMAP accounts. IMAP accounts deliver to their own folders - this is because they are server accounts. If you want everything in one folder you need to use POP3.
P Outlook 2013 Purge Using Outlook 3
F have to purge to delet Using Outlook 1
A Search People>press enter box disappears. Using Outlook 3
S Default Selection For Multi-Select List Box Outlook VBA and Custom Forms 1
A GetSelectNamesDialog Pre-fill search box Outlook VBA and Custom Forms 12
P Custom Outlook form_Validations in combo box Outlook VBA and Custom Forms 0
K Sharedmail box Outlook VBA and Custom Forms 4
Diane Poremsky Outlook Suggestion Box at Uservoice Using Outlook 0
D Emails do not appear in Sent box! Using Outlook 4
Kristine RS box added in Favorites disappears Using Outlook 6
rohit I want to Populate Popup box while sending any email with attachment. Outlook VBA and Custom Forms 4
rohit I want to Populate Popup box while sending any email with attachment Using Outlook 1
Ross Garvey Dialogue box opens as I exit Using Outlook 2
P BCM 2013 Contacts Form Drop Down Box Bug BCM (Business Contact Manager) 1
G Enter Network Password box pops up every few seconds Using Outlook 2
S Outlook form - Combo box for deciding who to send form to Using Outlook 1
V In Box Issues Using Outlook 1
S Custom yes/no message box. Using Outlook 0
L Auto-set followup/reminder popup box for ALL sent emails. Using Outlook 0
P VBA for Dialog Box when sending Email Using Outlook 8
M Send receive Progress Box Using Outlook 4
