Highlighting / Fomatting appointments in Timeline view
bluphoto
I have a custom "today" page in which my calendar timeline is displayed, along with inbox, tasks etc. The timeline is the only view I've really come across which lets me fit a decent amount of information in the space I have available.
I was hoping someone could tell me how to format the appointment headers in the calendar view - perhaps greying out appointments which are already past, or highlighting the "next" apointment in red / yellow etc.
Even if I could do this manually, it would be better. Right now the timeline view is quite congested, which makes reading appointments at a glance difficult.
thanks
Guy
the picture is a little small to see exactly how you did it, but if you are using the view control, try right clicking on the row of field names - do you get a menu to customize views? You can gray out yesterday's appointments but not one that just ended a hour ago - use automatic formatting. Another option is using categories to mark appointments 'completed' then use automatic formatting to change the font.
S Outlook 365 Can I change the possible range of highlighting colours when writing an Outlook email? Using Outlook 1
D Search Results Highlighting even in the search folders Using Outlook 1
Yusufbodrum Highlighting selected mails in any folder Using Outlook 2
S email inbox highlighting Using Outlook 1
R OL2010 Calendar Appointment Highlighting Text issue Using Outlook 3
A Outlook 365 New Appointments All saved to a 365 default calendar on Mac Using Outlook 0
M New Calendar Appointments: Conditionally turn off reminder and show time as free Using Outlook 14
M Printing Appointments Using Outlook 1
M Calendar daily Appointments and printing Using Outlook 0
L Option to Show Cancelled Appointments Using Outlook 0
O Export Outlook calendar appointments by filters and date range Outlook VBA and Custom Forms 1
N Gathering Calendar Appointments from Calendars that synced as Contacts Exchange Server Administration 1
F Year-and-a-day recurring appointments Using Outlook 1
J what file contains contacts, tasks and appointments stored locally? Using Outlook 1
D hiding appointments that are completed or cancelled, how to ? Using Outlook 5
M warning for too many appointments on a same day in Outlook Using Outlook 1
OutlookIntegrator Appointments Using Outlook 0
R Make past appointments remain in calendar Using Outlook 1
M Creating Outlook Appointments from Excel Cells Outlook VBA and Custom Forms 1
A Outlook.com changing appointments Using Outlook 8
T populate calendar with appointments and send reminders Using Outlook 1
Diane Poremsky Create Appointments Using Spreadsheet Data Using Outlook 0
Diane Poremsky How to Import Appointments into a Group Calendar Using Outlook 0
I Outlook 2013 Appointments not in HTML Using Outlook.com accounts in Outlook 2
makinmyway Appointments Created in iCloud Calendars Cover Contacts Field...Why? Using Outlook 3
M Expected behaviour of recurring appointments? Using Outlook 2
C Find all deleted recurrence appointments Outlook VBA and Custom Forms 4
G Outlook does not show new appointments in To-Do-Bar Using Outlook 0
A Looping appointments in calendar Outlook VBA and Custom Forms 0
B Outlook Calendar/setting appointments Using Outlook 1
L Appointments disappearing Using Outlook 0
N To do bar - show more than 30 days of appointments Using Outlook 0
A Show ALL of today's appointments in To-Do Bar Using Outlook 1
F Outlook 2007 Calendar Appointments not in Outlook Today view Using Outlook 11
A Can't stop Outlook.com from setting reminders on appointments? Using Outlook.com accounts in Outlook 3
S Outlook 2013 Appointments missing Using Outlook 1
N Outlook Shared appointments automatically to Private Calendar Using Outlook 1
A Synchronize Access Table with Outlook Calendar Appointments Outlook VBA and Custom Forms 3
J Change reminder times of future appointments Using Outlook 1
Mark Rideout Search folder for appointments and emails Using Outlook 2
C Appointments from Excel to Outlook Using Outlook 3
