Time Zone Problems with Internet Calendar
Hi Diane, hi basementclev2
Thanks for your quick replies!
Problem solved. I'm sorry, my mistake: Instead of subscribing to webcal://whatever.something.ch/numberOfTheCalender I subscribed to http://whatever.something.ch/numberOfTheCalender
The calender worked, except that it didn't consider daylight saving time. Now everything is fine.
Thanks again!
M Calendar Time Zone issue Using Outlook 0
P Outlook 2013 to Outlook.com Time Zone sync Using Outlook 4
A Calendar time zone Using Outlook 1
Diane Poremsky Use VBA to get an Appointment's Time Zone Using Outlook 0
J Calendar Appointments move when Computer Time Zone changed. Using Outlook 5
B Outlook Calendar - Time zone changes after the meeting request is accepted. Using Outlook 1
D Outlook 2007 Reminder Times Change When User Changes Time Zone in Date/Time Using Outlook 4
K Outlook for Mac problems Using Outlook 0
