Installation BCM impossible due to untraceable old SQL-server remains
Paul Kortman
Outlook 2013 32 bit
After a crash of my SDD, I tried to reinstall BCM (2010) in Office 2013 on the new sdd. The installation was not fully ended. There appeared a message that there were remains of an earlier version of SQL server still active or .
More exact I did the following things.
First I made the mistake of installing the 64-bit version, while I run Outlook 32-bit.
Then I tried the installation a few times, but failed.
After that I had a long conversation with someone from Microsoft, who with remote help erased all traceable threads of SQL server. All treable, because BCM keepsrefusing to install.
At the end the man from Microsoft came with total solution, so popular with helpdesks nowadays. A total reinstallation of the hdd. You can imagine my reluctance to do so. Certainly after I had to do that time consuming and stressy procedure only a few weeks ago.
Is there anyone here, a guru, a freak, a wizard, maybe even Bill himself who knows another more easy solution? Please?
Version 2, without some bugs removed:
After a crash of my old SDD, I tried to reinstall BCM (2010) in Office 2013 on the new sdd. The installation was not fully ended. There appeared a message that there were remains of an earlier version of SQL server still active or present.
After that I had a long conversation with someone from Microsoft, who with remote help erased all traceable threads of SQL server. All traceable, because BCM keeps refusing to install.
At the end the man from Microsoft came with the total solution, so popular with helpdesks nowadays. A total reinstallation of the hdd. You can imagine my reluctance to do so. Certainly after I had to do that time consuming and stressy procedure only a few weeks ago.It takes more than a day to get the pc back in its old state.
Don't you love the old standby solution, "Format C:" :)
Go into Control panel, search for 'add remove programs' - is sql and bcm still listed? If so, uninstall every sql item listed and BCM, then reboot.
The Microsoft guy did even delete every hint in the registry. There must be someone up there who knows what is checked to let the message appear.
So they cleaned out all sql keys in the registry and it still says its installed? Is there any sql entry in Add & Remove Programs? (SQL adds a lot of entries.) Are there any SQL folders on the hard drive - use search to look for sql.
I recently upgraded outlook from 2007 to 2013 I was trying to install BCM and received the error message "Microsoft sql server express installer reported an error" how can I get BCM installed? I was not using an earlier version of BCM
J Need help with installation of BCM in Outlook2013 BCM (Business Contact Manager) 5
J BCM Installation problem BCM (Business Contact Manager) 1
J Outlook 2007 with BCM - Out of Memory after MSO12 SP2 installation BCM (Business Contact Manager) 4
DoctorJellybean Use OST file location for fresh installation? Using Outlook 1
DoctorJellybean Preserve OST file location in new installation? Using Outlook 4
Diane Poremsky How to Uninstall Outlook from an Office Installation Using Outlook 0
N Outlook 2013 installation error Using Outlook 1
icacream outlook 2007 installation file.... Using Outlook 2
V need installation file Using Outlook 5
T I've broken my installation (OL 2013) Using Outlook 0
N Citrix installation possible? BCM (Business Contact Manager) 1
I Post outlook connector installation syndrome - Standby gone Using Outlook.com accounts in Outlook 3
A Installation Issues with Outlook Add-In 2003 Outlook VBA and Custom Forms 1
T How to Cancel a queued addon installation on Outlook2003 Launch Outlook VBA and Custom Forms 1
V how to collect details from user, during installation of office addin? Outlook VBA and Custom Forms 1
A Custom Form installation Outlook VBA and Custom Forms 4
Y Outlook 2007 add-in installation problem on Vista Outlook VBA and Custom Forms 1
M VSTO 2007 Addin auto-disabled on one machine but not another on installation? Outlook VBA and Custom Forms 1
N VSTO outlook 2007 addin installation problem Outlook VBA and Custom Forms 1
R RE: Installation Problem BCM (Business Contact Manager) 3
U looking for feedback on installation process and on eMarking Assis Outlook VBA and Custom Forms 1
