Task macro to save task into specific folder
Backtobasic
Hi all,
Appreciate any insight anyone may have. I am very bad at basic and have tried a lot of trial and error.
I have a shared folder between myself and a co-worker and we have a list of tasks that we both update with new tasks.
I created a macro to automatically create " New Task " and open a pre-made template.
Sub FINAL()
Set msg = Application.CreateItemFromTemplate("C:....FINAL.oft")
msg.Display
Now the problem comes when he saves and closes, it saves to his personal task folder.
Is there a way to add to my macro so when he saves it will automatically save to my personal folder "name@name.com" instead of his?
He has full owner permissions.
Thanks in advance!
Bachelle Macro to Update Existing Task from New Email Outlook VBA and Custom Forms 3
L Change Category in a Task via macro Using Outlook 8
N Macro to create task Using Outlook 1
S Macro to create a new contact, 2 appointments, and a task Using Outlook 1
sjbtax Update Task Custom Field based upon Task Overdue Status Outlook VBA and Custom Forms 8
K Daily Task List Minimized Cannot Display Using Outlook 5
wayneame Changing the Form Used by Existing Task Items in a Folder Outlook VBA and Custom Forms 4
S Outlook 2016 Understand and customize prepended behavior of recurring task Using Outlook 0
K Multiple copies of task being created Using Outlook 2
P Short Date Format when typing in a task Using Outlook 2
C Outlook 2013 Task Recurrence - Third Friday After the Second Tuesday Using Outlook 2
P Task display now leaves little room for notes Using Outlook 10
C-S-R How to clear an Outlook (To Do) Task Flag? Using Outlook 8
G Event when creating task from mailitem Outlook VBA and Custom Forms 2
D How To Combine Share Task Folders in just one Folder Using Outlook 0
G Arggh, weakness of reminder for every Task recurrence Using Outlook 0
P Can't paste an image into a task Using Outlook 3
J Office 365 erased all of my task views Using Outlook 3
T Report For Task Recurrance Outlook VBA and Custom Forms 4
E Can't accept or decline task (no button appears) Using Outlook 2
X If you change expiration date of repeated task it dupplicates Using Outlook 1
Z How to show concatenated categories in list task view? Using Outlook 2
Z VBA to Collapse Task Folder Groups Outlook VBA and Custom Forms 1
M Daily Task List Minimized Cannot Display Using Outlook 2
S Codes for "Mark Complete" the task Outlook VBA and Custom Forms 2
W Deleting Sent Task Email, Deletes the task from my list Using Outlook 1
K Task priority modification Using Outlook 4
F Search folder for tasks in all task folders Using Outlook 1
K outlook workflow: automated task generation Outlook VBA and Custom Forms 4
F How to assign a task to a public task folder? Using Outlook 1
