Autocomplete issue
Adrian
When I type a letter( ex: A) in the TO field I get NOT only addresses that start with that letter but also addresses that start with other. I checked the address and the display name, and both are different than what I'm searching.
After I delete the wrong suggestions from autocomplete and then send an e-mail to those again, they are still being saved and displayed in a wrong place.
That is the problem the display and the email doesn't begin with "a". It displays just a random address that has no connection to the letter I type....
By pressing the "Empty Autocomplete" won't that delete all the addresses there ?
Thank you very much for your help!
J Outlook Autocomplete (Recipients) opens upward Using Outlook 2
N How do I make Outlook autocomplete addresses from a list of recognised <full_names> only? Using Outlook 2
C Outlook Autocomplete suggestions showing wrong person's name against an email address Using Outlook 0
V Autocomplete not working on new email account Using Outlook 4
G Autocomplete adds suspicious "@unknown.email" to selected contacts Using Outlook 1
M Outlook.com autocomplete list invaded by strange items Using Outlook.com accounts in Outlook 7
M email autocomplete broke.. Using Outlook 5
C Autocomplete losing some (not all) addresses Using Outlook 6
N Importing Google contacts from CSV file removes recipient names in autocomplete list Using Outlook 0
V Outlook 2013 - transfer autocomplete data Using Outlook 4
Michael Durthaler Outlook 2013 Autocomplete File Is Infected Using Outlook 1
U Autocomplete not working Using Outlook 5
S Recover Autocomplete After Computer Failure Re-install Using Outlook 3
G Outlook 2013 AutoComplete Limit Using Outlook 3
Z Copy Outlook 2007 "AutoComplete Contacts” to Outlook 2010 Using Outlook 7
J autocomplete in "To" field does not work for display names Using Outlook 8
U Imported contacts to appear in Autocomplete Using Outlook 1
V Outlook 2010 Autocomplete Using Outlook 7
N Outlook should use address in address book before the address in Autocomplete Using Outlook 0
A Help with random numbers in autocomplete emails Exchange Server Administration 3
K Autocomplete list not saving distribution list Using Outlook 3
T Autocomplete, although enabled, does not complete names in TO: Using Outlook 4
G Data Left Behind when Migrating To Outlook from Thunderbird - Insights on the Issue Using Outlook 0
C Solving the "indexing never finishes" issue Using Outlook 8
Z Hotmail account deleted from outlook and issue with account not exist Using Outlook 0
H Outlook 365 issue getting details from embedded files, crashing routine Outlook VBA and Custom Forms 0
A Clipboard Resize Issue Using Outlook 7
D hide messege issue Using Outlook 1
B Outllok 2007 License Expired issue Using Outlook 0
