Calendar - color coded items are now the same color
Dave Horne
Outlook 2019 64-bit
For some reason all of my Calendar items (Birthdays, Medical appointments, etc.) are now the same color. I would have appointments color coded so they would stand out from each other.
The only thing I can think of that could have cause this was synchronizing my Calendar (and Contacts) items to my new Huawei P7 mobile telephone.
Thoughts?
If you display the Categorize dialog for an appointment item and see the item's category shown as 'xxx (not in masterlist)', then most likely the sync software deleted your master category list. If that's the case, you need to recreate it, and see if you can get a fix for the sync software.
Michael, when I click on a recurring appointment like someone's birthday, and then click on Categorize All Categories, all the color boxes are unchecked ... it's as if they were never color coded to begin with.
C Color Code New Calendar Items Using Outlook 2
J Color Alignment on the Calendar? Using Outlook 2
B Sub Calendar-Color Coding Issue Using Outlook 4
C Sync color categories on a Public Calendar across Office 365, PCs, Macs Using Outlook 1
T Setting Color codes for each user of a shared Calendar Using Outlook 1
E Calendar Thumbnail current day background color Using Outlook 3
M Auto-color all Calendar items based on condition: Private Using Outlook 6
M Calendar draft notice - automatically color code? Using Outlook 1
D Add color to calendar items automatically? Using Outlook 1
S Calendar background color Using Outlook 10
G Forms error on iCloud calendar Using Outlook 18
V select default calendar Outlook VBA and Custom Forms 3
M Calendar items have a pale pink blushing Using Outlook 3
T Cannot delete a calendar Using Outlook 0
F Show events in Monthly Calendar Using Outlook 3
J Calendar events created on iPhone automatically changing default alert from 'None' to 'Time of Event' Using Outlook.com accounts in Outlook 0
A Outlook 365 New Appointments All saved to a 365 default calendar on Mac Using Outlook 0
V Unchecking my calendar and leaving shared one visible Outlook VBA and Custom Forms 1
M New Calendar Appointments: Conditionally turn off reminder and show time as free Using Outlook 14
J Cannot edit a calendar event received as an invitation Using Outlook 2
e_a_g_l_e_p_i Question about calendar Using Outlook 5
icacream Outlook 2021 - Google calendar in the peek Using Outlook 0
