Desktop shortcut
Did you run scanpst on it? http://www.outlook-tips.net/beginner-user/use-scanpst-to-repair-outlook-files/
if you did and it still won't open, go to Control panel, Mail and edit your profile - add a new pst and set it as the default. Remove the 'bad' pst and note it's file location. On the email tab, select each pop account and verify the path beside the change folder button is pointing to the new pst file. Outlook should open. Try opening the old pst using File, Open, Outlook Data File - if that works, you can move or import the contents of the old pst.
G Keeping Outlook Classic (desktop) PST in Google Drive folder? Using Outlook 2
T Where has the Copilot icon gone in my Outlook desktop client? Using Outlook 10
D.Moore Outlook desktop client suggested searches question Using Outlook 22
G Reduce whitespace in Outlook desktop Contact Cards display Using Outlook 3
D Outlook Desktop App Email Software Using Outlook 0
S Import pst file into 365 desktop and have it sync one Using Outlook.com accounts in Outlook 2
kburrows "New" Outlook Desktop App Mailbox Size Using Outlook 4
J Hotmail drafts started on desktop disappear, but show in web version of Outlook Using Outlook 4
J 'Name on the security certificate is invalid or...' - Outlook on desktop talking to hotmail.com account Using Outlook.com accounts in Outlook 6
P Email address auto-completes work fine on laptop, but no longer on desktop Using Outlook 3
e_a_g_l_e_p_i Question about installing my Gmail account on my iPhone but still getting messages downloaded to my desktop Outlook. Using Outlook 3
D Unable to view older emails in desktop app Using Outlook 0
D Office 365 Outlook desktop app prompts for all account passwords on startup Using Outlook 11
C Why does Outlook (desktop) 365 for Windows keep making me input my passwords? Using Outlook 12
M McAllister Outlook stops Sending/Receiving/Synching after disconnecting remote desktop session Using Outlook 2
B How to get ALL Internet headers in Outlook desktop? Using Outlook 1
T Copying Outlook Account Setup For Desktop App Using Outlook 5
Travis Lloyd Linking Outlook 2016 Desktop To POP3 Acc't On Android Phone Using Outlook.com accounts in Outlook 2
copperberry Outlook 2013 (desktop) vs Outlook 365/Outlook 2016 Using Outlook 7
L Save message from outlook to desktop in 2013 outlook Outlook VBA and Custom Forms 1
M Outlook 2016 Desktop - Automatic Rule Processing Using Outlook 3
Travis Lloyd Will Outlook 2016 Desktop Sync-up With Outlook.com? Using Outlook 8
T Desktop alerts show but no emails found Using Outlook 1
I Outlook 2010 Replicating mixed PST/OST profile to another desktop Using Outlook.com accounts in Outlook 1
H Move outlook emails >90 days to shared drive (Desktop) Folder Outlook VBA and Custom Forms 5
P Desktop Outlook not sending from alternative email Using Outlook.com accounts in Outlook 6
D Desktop alerts not showing for folders other than inbox Exchange Server Administration 1
K Visual of Tasks on desktop Using Outlook 2
P Outllook on a laptop and desktop Using Outlook 1
P Sync 2013 calendar between 2 devices -Surface 2 and Desktop using Outlook.com Using Outlook.com accounts in Outlook 8
T Outlook Calendar Sync MY GOAL: see work calendar on home desktop w/o OWA Using Outlook 2
mikecox Accessing Outlook on my Win7 desktop from Win8 laptop Using Outlook 1
L Oulook Size On a Desktop Screen Using Outlook 2
D Great Outlook App That Allows Contact Search from Desktop Using Outlook 0
E No Contact Pictures in Desktop Alerts Using Outlook 10
D Android/desktop App for sending to Outlook inbox? Using Outlook 1
U How does outlook desktop work with outlook.com Using Outlook 5
makinmyway Help Using Windows Desktop Search to Index Outlook PST of another User Logon Using Outlook 14
M Windows desktop search not available Using Outlook 2
