Are there any Sound options for Office 2016 specifcally for outlook?
YSLGuru
OS Version(s)
  1. Windows
Outlook 365 64 bit
Does anyone know if Office 2016 has any options sound like highly popular Office Sounds add-in that was support in Office up thru Office 2007? I am particularly interested in the sounds that were for OL like the one that would play when you re-sorted the inbox.
D Sound when receiveing mail. Using Outlook 2
B outlook 2010 - email sound notification Using Outlook 3
O Junk E-mail Options disabled(?) Using Outlook 3
J Why are my Junk options shown as slashed off Using Outlook 6
S mouse right click options Using Outlook 2
S Navigation Pane Location And Options Using Outlook 19
S Is it possible to cusstomise selectable Options in Kalander. Outlook VBA and Custom Forms 1
Jennifer Murphy Calendar options Using Outlook 1
Gary Hile Outlook 2016 changing editor options Using Outlook 6
Diane Poremsky Change Outlook's Programmatic Access Options Using Outlook 0
rerun101 Question about message options Outlook VBA and Custom Forms 4
I Outlook 2016 Preview Address Book Options Using Outlook 2
Diane Poremsky No drop down calendars in Outlook 2010 Print Options Using Outlook 0
C Autofill subject line in appointment from options selected in combobox Using Outlook 6
Steve Jacobs Possible to configure TNEF options based on *sender*? Exchange Server Administration 3
mrje1 Junk Options - Safe Lists not working. Using Outlook 0
P Cannot open Options Menu Outlook 2007 and Cannot create a new profile Using Outlook 0
Commodore Color options in 2010... Using Outlook 0
H Date options on Customized Contact form Using Outlook 2
S Exam 77-884: Managing Contact Module Options Using Outlook 4
J Outlook replacement options - contact journal activities lost Using Outlook 23
M Is there a reference for the valid XML tags and their options? Using Outlook 3
H Issue with Custom Voting options Using Outlook 3
H mark as read per folder options Using Outlook 1
H Contacts View > Arrangement options are all grayed out Using Outlook 5
F Can't set work time in OL 2010, all options are grayed out. Using Outlook 2
S Organizer of meeeting options not present on past meetings Using Outlook 1
R Outlook Options can not be saved Using Outlook 0
R Get AutoArchive settings (as set from Tools|Options|Other|AutoArch Outlook VBA and Custom Forms 1
S Outlook Email Help: Select custom voting button options VBA Outlook VBA and Custom Forms 1
T Outlook setting through code(in >tools >options) Outlook VBA and Custom Forms 1
R Outlook eating up delete keypress Options Outlook VBA and Custom Forms 6
T Outlook 2007 Indexing Options and Advanced Search options disabled Using Outlook 5
C Which version of Office? Using Outlook 4
P newly installed Office 365 includes OLD Outlook Using Outlook 6
Y Q's Regarding Office 2019 Using Outlook 0
S Import PST to Office 365 Using Outlook 1
C Migrate Exchange to Office 365 Using Outlook 2
S Outlook 2016 and Acrobat PDFMaker Office COM Addin Using Outlook 0
U Rolling Back Office broke automatic updates Using Outlook 4
