Help: set flag for sent mail to check if received an answer
lizoutlook
Outlook 2019 32-bit
Hi, I could really use some help here!
I have never used VBA - but I sent a large number of emails every day and would need a way to quickly check which ones have received an answer.
It would be very similar to this post, but I am struggling to find out how to modify the script.
Any help would be much appreciated!
Thanks a lot!
You'd want to use Flag messages after sending macro on that page - either click Yes or no for each message or flag everything you send.
This one can check for follow flags and remove them when a message arrives. It will need tweaked to work for your scenario as it looks for matches in the inbox.
Did not test so it might be full of errors... this should find flagged sent item and unflag when the recipient replies.
Private objNS As Outlook.NameSpace
Private WithEvents objNewMailItems As Outlook.Items
Private objInbox As Outlook.MAPIFolder
Private objSent  As Outlook.MAPIFolder
Dim objOwner As Outlook.Recipient
Set objInbox = Session.GetDefaultFolder(olFolderInbox)
Set objSent = Session.GetDefaultFolder(olFolderSentMail)
Set objNewMailItems = objInbox.Items
Sub objNewMailItems_ItemAdd(ByVal Item As Object)
Dim intCount As Integer
Dim objVariant As Variant
' look for existing messages and remove the flag and reminder
For intCount = objSent.Items.Count To 1 Step -1
 Set objVariant = objSent.Items.Item(intCount)
 If objVariant.MessageClass = "IPM.Note" Then
    If  instr(1,LCase(Item.Subject), LCase(objVariant.Subject)) > 0 And objVariant.SentOn < Item.SentOn Then
' clear flag and category
With objVariant
    .ClearTaskFlag
    .Categories = ""
    .Save
M Help! Can't set up IMAP for gmail Using Outlook 2
