Outlook contacts not synchronizing with iPAQ
  • Thread starter Thread starter w johnson
W
w johnson
I have an iPAQ 1955 with recently replaced motherboard. Calendar and Tasks
synchronize and appear on the iPAQ. Activsync shows contacts have
synchronized but they do not appear in the iPAQ. Have performed a hard reset
of iPAQ, plus deleted and re-installed Activsync. No success. HP says if it
syncs anything it is a software issue not the hardware, so no help there. I
am using Outlook 2003 with Business Contact Manager. I would greatly
appreciate any suggestions.
You might get a response in the MS activesync group
public.pocketpc.activesync
"w johnson" <wjohnson> wrote in message
news:526E4CD1-3C6A-4A3E-B8FC-5DFF10069E0C@microsoft.com...
> reset
> it
> I
"w johnson" <wjohnson> schreef in bericht
> reset
> it
> I
You are prob syncing to outlook contacts, which is (obviously) completlyt
differnt from the bcm contacts. 2 different databases, no syncing between
them . Goog luck
If you are using BCM, maybe your contacts are in the BCM?
ipaq will not sync any BCM contacts, they have to be in the contacts folder
of Outlook.
Activesync will says "syncing contacts" even if there are 0.
Try putting one contact in OL (or a new one in) and see if it works, then go
from there ..
Frank
> reset
> it
> I
F Outlook's contacts Using Outlook 1
kburrows Outlook Automatically Merging Contacts Using Outlook 2
kburrows Outlook or Phone Combining Contacts? Using Outlook 0
W Migrating Outlook 365 Contacts & Calendar Using Outlook 2
R How to delete Facebook Contacts folder in Outlook 365 Using Outlook 7
C Import Outlook 2016 contacts into to: field Using Outlook 1
S Outlook.com birthdays show up 1 day late on iPhone contacts list Using Outlook.com accounts in Outlook 27
S Outlook.com cannot edit some contacts Using Outlook.com accounts in Outlook 5
S Missing Outlook calendar and contacts Using Outlook 0
Cdub27 Move Outlook 2016 Contacts to Other Folders - Extremely Slow !! Using Outlook 6
A add birthday to outlook contacts Using Outlook 1
O :Managing contacts in Outlook 2016 Using Outlook 0
E 365 Outlook changed from POP3 to IMAP,all contacts lost Using Outlook 3
