Categories not persisted between sessions in Outlook 2007
Teodora Gancheva
I have a C# COM Add-in for Outlook 2007 that adds categories to mail
messages programmatically. I use mapiNameSpace.Categories.Add method to add
the category to the Master Category List and the Categories property of the
MailItem to assign the category to the mail. This works fine and the category
is successfully added to the mail and to the Master Category List.
However, when Outlook 2007 is restarted only the category assigned to the
mail is persisted. The category disappears from the Master Category List.
I am using Outlook 2007 SP2 with Exchange account. Has anyone encountered
this issue before? I found very little information on the net about Outlook
categories, so any hint is highly appreciated.
Teodora Gancheva
K
Ken Slovak - [MVP - Outlook]
Show the code you're using.
"Teodora Gancheva" <Teodora Gancheva > wrote in
message news:6B31AF50-BE4E-4602-93C3-8DC4417E9A4F@microsoft.com...
> Hi,
> add
> the
> category
> Outlook
> Thanks,
> Teodora Gancheva
Teodora Gancheva
This is how I add the category to Outlook category list:
NameSpace mapiNameSpace = outlook.GetNamespace("MAPI");
mapiNameSpace.Categories.Add(categoryName,
OlCategoryColor.olCategoryColorNone,
OlCategoryShortcutKey.olCategoryShortcutKeyNone);
And then I assign the category to the MailItem:
mail.Categories = categoryName;
mail.Save();
Teodora Gancheva
> > Hi,
> > add
> > the
> > category
> > Outlook
> > Thanks,
> > Teodora Gancheva
K
I'm seeing it as a bug, it's not persisting here either. Structure your code
so you add that custom category when your code starts up.
I'll report it to MS and see what they say.
"Teodora Gancheva" <TeodoraGancheva> wrote in
message news:320B6CE5-840B-41EF-B57B-33C76C46B4E4@microsoft.com...
> mail.Save();
> Thanks,
> Teodora Gancheva
Teodora Gancheva
In the meantime I have tested the code on 5 different machines with Outlook
2007. It seems to be working on the RTM and SP1 versions. The issue only
exists with SP2.
Unfortunatelly, adding the categories upon start up is not applicable in my
scenario, or at the very least is very difficult. The reason is that I am
assigning different categories to different mail items upon user action, in
my case that is import of the email into an external system. I could probably
save the categories to some file and then upon start up read from that file
Anyways, let's see what MS have to say about this.
Teodora Gancheva
> > mail.Save();
> > Thanks,
> > Teodora Gancheva
K
The bug was verified by 2 other 's independently, so it's
definitely a bug. We all tested on Outlook 2007 SP2, so it's definitely
there.
It's been reported to MS, but I doubt anything will be fixed until SP3. It's
not a data corruption or loss problem that would require a hot fix, and the
product group is devoting most or all of their time at the moment to the
Outlook 2010 beta, so I don't see it getting high priority at this time.
BTW, the bug isn't there in the beta of Outlook 2010.
What I've done in addins where I use Categories is to have a list either in
Settings or in an XML file that I read at startup and then add my categories
to the collection as needed (if they're not there).
One of the other MVP's (who has an addin that manages categories) hacks any
custom categories into the binary property PR_ROAMING_XMLSTREAM (0x7C080102)
in the hidden item in the Calendar folder that is where the master category
list is stored. All the categories are stored there in that property in a
hidden item with the MessageClass of "IPM.Configuration.CategoryList".
Doing it that way will make the added categories permanent, since that's
where Outlook looks for the categories list. If you open that hidden item in
a MAPI viewer such as OutlookSpy (www.dimastr.com) or MFCMAPI you can look
at that binary property to see how each category entry is formatted. The
binary bits are actually XML text, so you can extract that and review how
each entry is structured. You could then get the bits as a binary array,
convert the array into a text string that's XML and use XML methods to read
and add nodes as needed. Then when finished you can simply convert the XML
text back into a binary array of bytes and write that back into the
PR_ROAMING_XMLSTREAM property on the hidden item.
message news:6E2BDC13-818C-4CAD-BA3F-796F8D41031B@microsoft.com...
> Hi,
> Outlook
> exists with SP2.
> my
> in
> probably
> file
> Thanks,
> Teodora Gancheva
Teodora Gancheva
Thanks a lot, all the information has been really helpful.
> there.
> > Hi,
> > Outlook
> > exists with SP2.
> > my
> > in
> > probably
> > file
> > Thanks,
> > Teodora Gancheva
K
It looks like there's a hot fix available for this issue (among others). A
fellow MVP pointed me to this link:
http://support.microsoft.com/default.aspx/kb/970944/en
message news:A052F571-6C43-4BC9-B857-82D75218E2A0@microsoft.com...
Teodora Gancheva
Installing the hotfix resolved the issue.
Teodora Gancheva
S Folder Pane Colour Categories Using Outlook 6
Ken Pascoe Outlook Categories Quick List Using Outlook 0
O Calendar - appointment templates and categories Using Outlook 1
T Increasing the number of items that appear on the Categories list Using Outlook 2
D Assign categories to outgoing emails Outlook VBA and Custom Forms 0
Z How to show concatenated categories in list task view? Using Outlook 2
A Outlook reverse categories Outlook VBA and Custom Forms 1
Mark Foley Color Categories on IMAP mail lost when installing new Windows 7 workstation Using Outlook 12
P Task Categories Using Outlook 2
I categories for outgoing email Outlook VBA and Custom Forms 7
S Appointment colour categories disappear Using Outlook 4
Z Outlook.com Contact categories Using Outlook 8
Diane Poremsky Using Categories for Dynamic Distribution Lists Using Outlook 0
avant-guvnor Outlook 2016 and views, categories etc. Using Outlook 3
T categories in Outlook 2016 Using Outlook 0
makinmyway How to Easily/Quickly Ungroup by Categories Using Outlook 1
C Printing tasks with multiple categories Using Outlook 5
Mark Foley Where are Outlook categories save for IMAP? Using Outlook 12
T Outlook 2007 adding categories Using Outlook 15
E Outlook 2013 is stripping out categories on sent meeting invites Using Outlook 0
Karlski Deselecting categories often takes 3+ attempts Using Outlook 3
Diane Poremsky How to Upgrade to Color Categories Using Outlook 0
K Missing Categories & Colors Using Outlook 5
V Outlook 2010 – Send email based on categories Using Outlook 2
W Sync categories between Exchange and 2007 Exchange Server Administration 1
C Adding Categories when Composing Email Using Outlook 1
D Error in the Categories view Using Outlook 2
J Lost email categories when migrating from Office 2010 to Office 2013 Using Outlook 3
Semipro50 CATEGORIES Using Outlook 4
B Outlook 2013 categories Using Outlook 1
N Using Categories & Search Folders with multiple accounts Using Outlook 4
D Multiple values for a field (like categories) Outlook VBA and Custom Forms 1
