how can i re-order recipients (addressees) in alphabetical order?
  • Thread starter Thread starter cj
See this space?
Use it to create a clear question. Your Subject does not contain one.
Russ Valentine
"cj" <cj> wrote in message
news:67B51056-87E0-4EC4-8719-9C7E60C62C3A@microsoft.com...
<nothing
Why do you care?
Paste them into Excel,then Text to Columns, cop, Paste Special,
Transpose, Data, Sort, A>Z
<nothing
Why do you care?
Lotus Notes has this feature. (Probably the only thing about it that is better than Outlook, IMHO)
When you have a lot of recipients in an email thread and you are looking to make sure a certain person is included or not included, alphabetical sorting is very convenient. Pasting in Excel is not a helpful solution. Any number of manual work-arounds could be conceived. If Outlook has this capability and an expert in this forum can advise that would be helpful.
L However, before you place an order, you want to pick out whether or not you want the to Using Outlook 0
A Order of Recent Items in Attach File List Using Outlook 5
C Outlook Mobile app email order randomized and display names stripped Using Outlook 6
D Change First/Last Order of Contact Names (O 2016) Using Outlook 0
R Print email message and attachment in order Outlook VBA and Custom Forms 2
T Unexpected change of the order of the folders in my navigation pane Using Outlook 6
D Inconsistent order of names displayed Using Outlook 7
D Contacts Sort Order Using Outlook 0
A BCM 2010 account names import in reverse order BCM (Business Contact Manager) 4
B Outlook 2007 Mail Accounts Order? Using Outlook 2
T Change order in which multiple exchange accounts are displayed in outlook tree Using Outlook 6
W Page Order Outlook VBA and Custom Forms 1
D Tab Order Out of Sequence After Attaching Document Outlook VBA and Custom Forms 1
S Customing tab order in email template Outlook VBA and Custom Forms 1
S Question of setting the order of a custom menu in Outlook Outlook VBA and Custom Forms 1
J Outlook Autocomplete (Recipients) opens upward Using Outlook 2
M Outlook 2016 IOS recipients receive my paragraph double space as quadruple space Using Outlook 2
B Removing Recipients from an automatic response Outlook VBA and Custom Forms 2
S What is /O=FIRST ORGANIZATION/OU=EXCHANGE ADMINISTRATIVE GROUP(***************)/CN=RECIPIENTS/CN=... Using Outlook 5
V Safe Recipients list Using Outlook 0
Diane Poremsky Foward a Message and CC the Original Recipients Using Outlook 0
Z Item.Recipients for Task Assignment on Send Outlook VBA and Custom Forms 10
B Print list of previously sent recipients Using Outlook 1
daveTQM Add email recipients to contacts Using Outlook 1
M Charter ISP Claims Outlook Generating STMP Errors of Too Many Recipients Using Outlook 1
D Meeting Request - Too Many Recipients Using Outlook 0
Fozzie Bear Change the Display Name recipients see for Exchange account Exchange Server Administration 0
D Delay Delivery: Visible to recipients? Using Outlook 1
P Your message did not reach some or all of the intended recipients. Using Outlook 2
L recipients are not recieving my outgoing emails Using Outlook 1
C Your message did not reach some or all of the intended recipients. Using Outlook 2
T Outlook 2013 Duplicate Recipients Using Outlook 9
E msg attachments lose their recipients "smtp" address Using Outlook 2
S Automatically move recipients to BCC field Using Outlook 3
S Undisclosed recipients Using Outlook 2
T Attachment sent from Outlook 2010 not shown by recipients Using Outlook 20
