Outlook 2013 has two sets of contacts
IDgirl
Outlook 2013 64 bit
I just got a Win 8 machine and added Outlook 2013. I imported my contacts from a .csv file with no problem. However, once I started adding new contacts, they are shown in a different group in the "People" pane. The imported contacts are filed under the title "Outlook Internal Version (none)," and the new ones are titled "Outlook Internal Version 154,454." How do I merge the two?
Many thanks!
R Outlook 2007 to 2013 PST still has the 07 size limit not bigger 13 limit Using Outlook 3
C Outlook 2013 has been a disaster Using Outlook 8
P Outlook 2013 search no longer works Using Outlook 2
R Folders shifting around in Outlook 2013 and 2016 Using Outlook 3
J Outlook 2013 when clicking To in a new email show Company names Using Outlook 0
M OUTLOOK 2013 CONTACT PROPERTIES Using Outlook 0
M Outlook 2013 Using Outlook 1
J Outlook 2013 hanging for unknown reason Using Outlook 1
K Rebuilding Outlook 2013 from Outlook.com after OS rebuild Using Outlook.com accounts in Outlook 2
