Outlook 2003 error-Microsoft outlook has encountered a problem
  • Thread starter Thread starter JamieRG
ArunOnline said:
I'm getting the same error too from today. Any clues ?
Mikksa,
I fixed the problem as using your solution.
One thing I did deferent was all of our computers at work are RISed and they have msmapi32.dll (11.0.5601) in I-386 folders seperately.
I copied it from I-386 folder and pasted it in C:\Program Files\Common Files\System\MSMAPI\1033 after changing the name of current msmpai32.dll to msmpai32.bak.
Then, I removed the current outlook account and recreated one, and it finally fixed the error.
EXCELLENT SUGGESTION.. YOU HAD SAVED MY DAY. WITH A .PST SIZE OF 7GB ON A POP ACCOUNT-- OTHERWISE, I WOULD HAVE HAD TO SPEND MY ENTIRE WEEK TO REINSTALL AND RE-DOWNLOAD MY EMAILS.
THANKS A LOT...
Johney,
Could you advise what the fix was? I am having same issue with 3.5 GB pst file.
Thank you,
I noticed that the one that I was working on would happen anytime that there was a Send/Receive.
All I had to do to fix it was to click on “Folder List” (located on the lower left hand portion of the window and looks like a folder)
Then go to “Sync Issues” (located on the left hand portion of the window and is under the user's Mailbox)
I deleted all the Sync Issues that were inside all of these folders (three different ones (Conflicts, Local Failures and Server Failures)).
This immediately solved my user"s issues. No further action was required.
I am having the same problem, BUT I JUST DONT FIND THE ANSWER. no where in microsoft.com says anything about it. have you come up with an answer?
Can you start the outlook via command prompt outlook.exe /resetnavpane and see if it works (Start -run-cmd)
Umapathy (உமாபதி) MCITP: Enterprise Support Technician, Consumer Support Technician MCTS: Windows Vista - Configuration, BSc, MCP, A+, MCDST
AppName: outlook.exe AppVer: 11.0.8010.0 AppStamp:43d16d53
ModName: msmapi32.dll ModVer: 11.0.8002.0 ModStamp:4373069d
fDebug: 0 Offset: 00021f57
Microsoft outlook has encountered a problem.
I am receiving the following above and can not seem to fix it. Does anyone have any ideas on how to fix it. As soon as I launch outlook, i get the microsoft has encountered a problem and needs to close. any help would be greatly appreciated.
Something similar I had couple weeks ago and unfortunately I couldn't solve the problem. Only some days ago I ran into an interesting tool on the Inet, which to my surprise settled those issues, perhaps it will be usable for you - recovery pst.
Hi all,
I'm using Outlook 2000, and get the following problem, a few seconds after I startup the program:
AppName: outlook.exe AppVer: 9.0.0.2416 ModName: ntdll.dll
ModVer: 5.1.2600.5755 Offset: 000116f4
Mikksa's solution:
I've been having the same problem for about three weeks and I've tried everything uninstalling, creating a new profile etc. found this solution on the Osnn.net forum which was related to some outlook calendar problem. The problem seems to be the msmapi32.dll file located in " C:\Program Files\Common Files\System\MSMAPI\1033" outlook needs to be closed before doing this I replaced the current file with and older version of msmapi32.dll (11.0.5601) and renamed the current msmapi32.bak (just in case something went wrong). I then deleted my current outlook profile (I'm using MDaemon connector) and created a new profile. so far no problems. reading through different forums there seems to be a lot of problems relating to the msmapi32.dll file and the mapi32.dll file. why doesn't MS support come up with an answer or fix?
I've tried to find that path but didn't succeed. Wat is the solution for Outlook 2000!?
Emonk
Hi all,
Mikksa's solution:
Emonk
C Outlook 2003 - error on startup Using Outlook 3
F error message 0x80040600 Windows XP Outlook 2003 Using Outlook 3
C compile error on previously functioning code outlook 2003 windows Outlook VBA and Custom Forms 1
N runtime error while loading of outlook 2003 plugin Outlook VBA and Custom Forms 1
T Outlook 2003 Custom Form Error Handling Outlook VBA and Custom Forms 8
D Outlook 2003 stopped dead Using Outlook 2
D Wishlist How to use 'app password' in Outlook 2003 after Google pulled plug on "less secure apps" Using Outlook 2
