Outlook 2003 error-Microsoft outlook has encountered a problem
  • Thread starter Thread starter JamieRG
I am also experiencing the same issue. Could you please send me the msmapi32.dllv.11.05601 along with instructions to maiajones7@aol.com. Also, how do I download this file if I can't open up Outlook?
Good job! Replacing MSMAPI32.dll fixed the issue. I replaced it with a newer version of msmapi32.dll and it still worked.
I am having the same error problems. If someone has the msmapi.32.dll file (v 11.05601) please send it to me. I would appreciate it. It is worth a try. bleelt at att dot net
In the last few days, I've begun getting this same error message on Outlook 2003. Downloaded all possible updates, including SP3, to no avail. It seems that some have been having luck with this file - could someone please send it to me, please, at keri-c at cox dot net?
Thanks - Keri
Hey guys,
I found this thread while googling the error message and just wanted to say that I was able to stop this error when I disabled AVG's exchange extension. (client had AVG 8.0 free installed)
tools - options - other - advanced options - Add-in manager -
I can make the error happen 100% of the time If I enable this extension.
hope this helps someone else
I have been suffering the pains of this error for a week now. It seems to have occurred around the same time I upgraded to AVG 8.0 (purchased) and also Microsoft service pack 3.......
The suggestion re disabling AVG's exchange extension seems to work. However my question is what does the AVG exchange extension do in the first place?
More than happy to turn it off as long as it doesn't create any further issues.
I replaced the msmapi32.dll file and it didn't work, however disabling the AGV Exchange Extension has and with no impact on either AGV or outlook.
NB: I notified AGV Tech support and yet to receive an answer..... Hmmmmmm
Thanks for the fix
Wow, after putting up with this for some time, this is great info. After disabling the AGV extension, Outlook now closes properly. Thanks for the fix. I will be interested to see what if anything, AGV tech support has to say.
I removed all my Outlook Add-Ins and enabled them one at a time. I can recreate the problem consistently by opening a folder and clicking the up and down arrows a few times and will get it. It does close me out of Outlook and restarts it. I found that the Symantec AntiVirus Outlook Protection is the cause in my case.
Thanks for the help!!
Could you please advise me on how to disable the AVG exchange extension. I keep getting an error every time I open Outlook 2002?
If you are getting the following error...
"Outlook has encountered a problem and needs to close" .
Try disabling any password manager application like the HP Credential manager which comes installed on HP machines.
Also try removing unwanted windows start up items by going to Start > Run > msconfig > Hit OK > Start up tab
Me toooooo!... this is typical Microhard.... provide the software and no real fix... imagine if we were to sell products like Microsoft does !!!...
Could someone please email me the same file please..... I have tried almost everything... and I am not a dummy !
Thanks in advance...
I figured it out for my scenario. First note that I know what the trigger is to cause it to happen. For me, it is always clicking the up or down arrow within a message to go to another message. People here have had different symptoms and this fix seemed to work.
I removed all Outlook add-ins, tested and the problem was gone. Then I added one add-in at a time and everything was fine until I added the SAV add-in.
Yes. You may have to Reinstall your Outllook or perhaps do the ghost on you Pc foloow the rules into your company = ghost
C Outlook 2003 - error on startup Using Outlook 3
F error message 0x80040600 Windows XP Outlook 2003 Using Outlook 3
C compile error on previously functioning code outlook 2003 windows Outlook VBA and Custom Forms 1
N runtime error while loading of outlook 2003 plugin Outlook VBA and Custom Forms 1
T Outlook 2003 Custom Form Error Handling Outlook VBA and Custom Forms 8
D Outlook 2003 stopped dead Using Outlook 2
D Wishlist How to use 'app password' in Outlook 2003 after Google pulled plug on "less secure apps" Using Outlook 2
