Theme changing when 2nd monitor
liquidone
When laptop is by itself with no monitor plugged in, it looks normal, with a grey shade on the left pane so its easy to read text. See normal picture:
http://www.domesav.com/images/1.png
When a 2nd monitor is plugged in, it changes the way it looks to white all around, and icons seem to be at a lower bit-rate and Aero goes away (Just for outlook). See after picture:
http://www.domesav.com/images/2.png
All other programs seem to be unaffected. I have tried 3 different monitors of different size/resolution, and problem does not change. When 2nd monitor is unplugged, it does not go back to normal until a reboot.
Any Idea?
Mike
It looks like outlook is dropping down to 8 bit color. It's the video card, not the monitor, that is behind the problem (although I'm not sure whether outlook or the card is to blame). Check the card settings and see if anything catches your eye.
Is it the same if the monitor is connected when outlook is closed (then opened with the monitor connected)?
Didn't see anything in video card settings, and made sure it was up to date.
It does happen if monitor is attached first, and then outlook opens.
But....it is not 100% consistent, 1 out of 20 times it will stay OK when monitor is attached. Same routine is followed pretty much every time, so I don't know what could be different in those rare cases it works.
Is there a setting in outlook for how many bits it uses, because I couldn't find it? (Even if just it manually fix it after it happens.)
Mike
I Import Office theme .thmx Using Outlook 4
B Greying out the theme button in outlook Using Outlook 0
J Calendar events created on iPhone automatically changing default alert from 'None' to 'Time of Event' Using Outlook.com accounts in Outlook 0
F Auto changing email subject line in bulk Using Outlook 2
K Changing the Deleted Items location in Outlook 2019 Using Outlook 2
V Outlook 2021 Can anyone explain why my Outlook views keep changing?! Using Outlook 2
wayneame Changing the Form Used by Existing Task Items in a Folder Outlook VBA and Custom Forms 4
S Changing Message Class Outlook VBA and Custom Forms 4
C Pop Server Changing Verizon/Aol to Yahoo Using Outlook 6
Gary Hile Outlook 2016 changing editor options Using Outlook 6
T Changing default Mail Account in Outlook 2016 - POP3 Using Outlook 1
Stephen Weinberg Changing the mailing address checkbox Using Outlook 0
C Changing the name of Outlook Messages saved to a folder Using Outlook 1
A Outlook.com changing appointments Using Outlook 8
B Changing CC list to .add Outlook VBA and Custom Forms 2
Diane Poremsky Changing the Message Size in Exchange Server Using Outlook 0
Diane Poremsky Changing the default *.pst and *.ost sizes Using Outlook 0
P Message Class keeps changing back to IPM.Contact Outlook VBA and Custom Forms 2
L Office 365 Outlook changing default contact folder Using Outlook 0
Diane Poremsky Changing the From Domain in Office 365 Using Outlook 0
R The changing way to access information in Office 365 Using Outlook 0
