Arbitrary rules
bacchus
When making email rules in Outlook, why is "and on this machine only" default? What is this for? I have an outlook syncing program and am worried that my rules won't be synced. The same worry concerns moving my pst file to another machine (from my desktop to my laptop). I don't understand the purpose for this. Is it really common to make wholesale changes to rules on different machines?
What would be REALLY cool would be a program\script, whatever to make that imposed rule a choice or negate it all together.
For this machine only is used with pst files - rules that use the path of the pst won't work on another computer unless everything is identical. (For most people, its not, which is why they added the condition).
In Outlook 2007, rules are in the data file and this condition will help prevent the rule from being disabled when you use the pst on another computer. If your rules work fine on both computers with it disabled, then disable it when you create rules - but if any rules fail, then use it with 2 copies of the rule (one for each computer).
Thanks for the reaaly fast reply. OK. There are many backup programs and sync programs that can be "ported"(?) to other machines, even machines with different versions of Outlook and OS1 I imagine these capability has been around for a while. SynchPST does one and BackRex Outlook Backup does both. With the last, I can back up my PST file and outlook settings (sans email passwords) form my desktop running XP and office 2003 to my laptop running Vista (I've been meaning to change that) and Office 2007. I haven't NOTICED any problems with the rules but I suspect that in the port, the value changes to that default. It just seems that I'm always going back and unchecking that option. Heck, I don't even know what the consequences of not doing it would be.
OK. Let me think .... MS is afraid that if I use my PST on another machine, my rules will be disabled. So they defaulted to "For this machine only" so the rule WOULD be disabled in another machine? And they assumed that if we were sure that running that PST on another machine (you know, after the first try) would NOT disable the rules, we could\would uncheck "For this machine only"?
I'm not trying to be difficult. I just wanted to know what their thinking was. A part of my problem involves me being anal (no jokes, please). I have archive PSTs going back to 1989. I HAVE had reason to open, search and extract mail from these files. Not often, but once, it saved me $500. Having consistent rules is convenient.
Again, I'm sorry for my confusion and thank you for your help.
PS
I'm posting another query related to rules soon. I've been saving these questions for years and now that I'm unemployed, I finally have time to ask someone.:cool:
Microsoft definitely doesn't do things just for the heck of it. Most of the time, it's due to customer requests. This feature may be more useful with Exchange server accounts that can be opened on multiple computers - rules that use 'this computer only' are client side rules.
When you most the pst to machine #2, does the rule have 'the other machine only' in the title? if not, it may not affect you. I'd definitely see how it works with the condition set.
R How to simplify rules Using Outlook 2
J Recover server side rules from OST/PST without access to the server Using Outlook 2
K Multiple Rules on Single Email Using Outlook 2
Wayne Outlook locks up when opening "Manage Rules & Alerts" Using Outlook 7
B Setting rules Using Outlook 1
A rules not working Using Outlook 2
M Rules and autoreply Using Outlook 1
O How to recover rules after switch from POP3 to IMAP Using Outlook 2
N Copies of emails from rules have wrong from: account Using Outlook 0
L Office 365 cloud based rules Using Outlook 1
CWM030 Rules disappearing in OL 2016? ( Yes, I searched before posting) Using Outlook 7
R When rules lose track of "specified folder" Using Outlook 6
I Outlook 2013 Rules - (client only) Using Outlook.com accounts in Outlook 1
A rules (flags) not working Using Outlook 7
K Lost Rules. Assistant accesses my mailbox. Disappeared Using Outlook 0
R When rules are working but invisible and unmanageable Using Outlook 2
P Transport Agent or Rules/Connectors Exchange Server Administration 1
O Rules and Alerts for New Messages BEFORE sending Using Outlook 2
D Outlook Rules Using Outlook 1
Diane Poremsky Autoaccept a Meeting Request using Rules Using Outlook 2
Gunny NFOhiway Outlook PST file and Rules Using Outlook 1
M Outlook 2016 Rules Not Working Automatically Using Outlook 5
Diane Poremsky Rules & Alerts Dialog Won't Open Using Outlook 1
P Log of Rules that ran Outlook VBA and Custom Forms 3
P Recover / Extract Rules from standalone PST file creating RWZ file Using Outlook 2
