Help please
So far no issues have come up since I ran scanpst. That seems to have fixed the problem. Thanks for your help guys!
So the client finally did get a new message like he was getting before. Guess scanpst didn't work. I tried running it again and it found no errors.
Really? It's kind of odd that scanpst found no errors- it almost always finds something minor wrong.
Are all messages affected or just some? Were new antivirus definitions installed right before it started?
I'm guessing that it is a combination of the new defs and a malformed message header in some messages. Keep an eye on it... it's also possible running scanpst did something even though it said no errors found. Or closing and restarting outlook fixed it - years ago, restarting outlook fixed similar issues. (I think it was outlook 2002, but could have been 2000 or 98.)
Outlook
Hii........there is an chance that your messages and mails got corrupted in Outlook 2003!!!!!!
Re: Outlook
Is is plausible to think that if I switch the client from Outlook 2003 to Outlook 2007, that would help?
Re: Outlook
No, not really. Upgrading rarely fixes problems. If it does, it's usually because something in the upgrade process changed - add-in disabled, new profile, new data file etc. I would not spend money to upgrade in hopes it would fix the problem if I had the software available to me, I would probably try it.
A Help with VBA please! Outlook VBA and Custom Forms 15
C Please Help outlook 2013 Using Outlook 1
J Please help to clarify an IMAP issue Using Outlook 7
M Address book doesn't update contacts? Please any help would be great! Exchange Server Administration 4
N Please help....winmail.dat issue...slowly going insane..... Using Outlook 1
A help please -Boolean - can I use .AND NOT etc in a rule Exchange Server Administration 0
C Can't import distribution list - help, please Using Outlook 1
F Help with Outlook 2007 Macro Please! Using Outlook 4
V [duplicates duplicates duplicates] please help Using Outlook 26
I can't view email body please help! Using Outlook 6
S Please help! -- Linked Account field at Business Contacts tab is always empty BCM (Business Contact Manager) 1
A outlook error Receiving reported error (0x80040900) please help Using Outlook 4
D Help please my Outlook is frozen Using Outlook 3
H Outlook 2010: Cannot start!, please help me! Using Outlook 3
D Outlook 2007 not working>> Please help tried everything Using Outlook 3
U Need a help please Outlook 2007 crashing Using Outlook 2
M Updates to exchange server broke code - please help Using Outlook 2
K shared inbox help please Using Outlook 0
P Please Help me Create a Macro ! Using Outlook 2
D A little bit of help with headers please? Exchange Server Administration 1
L PLEASE HELP: reconnect existing PST file to imap account Using Outlook 5
L PLEASE HELP: reconnect existing PST file to imap account Using Outlook 1
B Please help! Outlook, Exchange Server, and Customization BCM (Business Contact Manager) 2
D Please help. My live.edu mail will not sync. Using Outlook.com accounts in Outlook 1
C outlook hotmail connector update killed my outlook - please help!! Using Outlook.com accounts in Outlook 3
M Help with shared BCM file please BCM (Business Contact Manager) 5
R i want notifier in outlook express , please help how can i get ? Outlook VBA and Custom Forms 1
R SQL Server Setup failed - Please help?! BCM (Business Contact Manager) 2
L Please help an idiot with BCM & Networking... BCM (Business Contact Manager) 5
V Import multiple vCard files!!!!!!! PLEASE HELP Using Outlook 2
V Outlook macro help please Outlook VBA and Custom Forms 23
