Using forms developed in OL 2007 in 2010
mcolyer
I built a custom contact form in outlook 2007. I am now working on a new corporate computer (I have all access to appdata) with outlook 2010. I have moved the form to appdata/local/microsft/forms AND appdata/roaming/microsoft/forms
But for some reason I cannot open see the form when I try to "design a form" in developer mode.
Is this because of a comparability issue between forms developed in OL 2007 and OL 2010??
Please help... extremely frustrated!
No, there is very little incompatibility between any version when it comes to forms.
Are you using a custom form or a template? Which Location are you selecting in Look in?
If the form was published to your mailbox, it should be in the mailbox's contacts folder.
It is a custom form. I was made while in the contact tool. The form works on 2007 but for some reason when I move it to my appdata/local/microsoft/forms folder... it shows up but does not show up in any folder when I am in contacts and select design a form on the developer ribbon.
D Using Follup in Custom Forms Outlook 2013 Using Outlook 9
R Viewing & Using custom forms/tasks in Outlook 2013 Using Outlook 1
L Help using forms in Outlook Outlook VBA and Custom Forms 2
