Language Issue
jasonhan82
I'm currently having an issue with outlook 2010 (exchange 2003) where by if i type a Japanese Language and sent out to an external domain, in between the email message, the Japanese language will have half of the email convert to Chinese language. But when trying to sent to an internal receiver, the issue did not persist.
Troubleshooting done :
-Exchange server patches are up to date with SP2 installed
-Installed Language Pack.
-International option is change to UTF-8 encoding
-New profile created
i have run out of idea what could possibly be the issue and i certainly hope someone has the answer for this issue.
it sounds like a Unicode issue - for whatever reason, everything changes to Chinese when something is wrong with the encoding or fonts.
What antivirus are you using? I know some scanners will corrupt parts of messages and since you say half is messed up, it sounds like a security scanner is touching it.
Are all messages affected or just some? The problem could be on the recipients side.
any users that are currently running on outlook 2010 has this issue.
Anti virus - Norton SEP 2012
Recipient issue - don't think so...most issue happen when they sent email to any external domain.
hmm... endpoint. I know it is responsible for a number of problems but i don't recall if this is one of them. Can you repro this at will? If so turn off SEP and see if the problem is fixed on new messages. Existing messages will probably remain 'broken'.
snissen Printing foreign language messages Using Outlook 1
O Windows 1803 update : QAT and toolbar changed, language pack gone... Using Outlook 5
S Outlook 2013 change proofing language Using Outlook 4
S Date/Time Field Natural Language Usage in VBA? Outlook VBA and Custom Forms 1
J Common runtime language? BCM (Business Contact Manager) 1
B Re: BCM failed to initialize the common language runtime BCM (Business Contact Manager) 4
T POP Sent Folder Synchronization Issue & Inbox Email Date Display Disorder Using Outlook 1
J Add imap account issue Using Outlook 9
C Solving the "indexing never finishes" issue Using Outlook 8
Z Hotmail account deleted from outlook and issue with account not exist Using Outlook 0
H Outlook 365 issue getting details from embedded files, crashing routine Outlook VBA and Custom Forms 0
A Clipboard Resize Issue Using Outlook 7
D hide messege issue Using Outlook 1
B Outllok 2007 License Expired issue Using Outlook 0
M Calendar Time Zone issue Using Outlook 0
B My outlook calendar edit issue Outlook VBA and Custom Forms 0
D Unusual calendar issue Exchange Server Administration 0
D Multiple Accounts Issue Receiving Emails in 2016 Using Outlook 0
B Winmail.dat Issue Using Outlook.com accounts in Outlook 0
tswatek Issue with where Outlook saves new contacts Using Outlook 3
K Outlook with MDaemon Connectivity Issue Using Outlook 4
G .ost file corrupted / solved the issue with some posts already said, but .ost file is corrupted agai Using Outlook 2
D Resizing issue for message field Outlook VBA and Custom Forms 0
P Outlook hanging issue Using Outlook 0
K Outlook 2013 calendar issue with Outlook.com Using Outlook.com accounts in Outlook 2
J Favorites in Public Folders issue Outlook VBA and Custom Forms 0
K Insert screenshots issue Using Outlook 2
B Sub Calendar-Color Coding Issue Using Outlook 4
T Using Outlook 2007 with Comcast (.pst inbox issue) Using Outlook 1
Brendan.Z Outlook 2013 signature editing issue Using Outlook 3
F Custom contact form icon issue Using Outlook 1
