Journal problem recording correct phone number
donwb
I use Outlook 2003 on Windows 7 Pro 64 bit
I am trying to use the code listed below to record a dialled number in Journal.
I use the autodialler function of Outlook, where I select between Business, Mobile & Home numbers.
If the listing in my Contacts folder has a Business number as well as a Mobile Number listed
and I select and autodial the Mobile number, the intention of the code is to record that Mobile number in the resulting Journal entry.
However, the Journal entry always lists the Business Number even though I selected and dialled the
Mobile number.
Is there a problem with the code?
Dim WithEvents m_colCalItems As Outlook.Items
Set m_colCalItems = objNS.GetDefaultFolder(olFolderJournal).Items
Set objNS = Nothing
Private Sub m_colCalItems_ItemAdd(ByVal Item As Object)
Dim objContact As Outlook.ContactItem
Dim strBusinessTelephoneNumber As String
Dim strHomeTelephoneNumber As String
Dim strMobileTelephoneNumber As String
Dim myUserProperty As UserProperty
Set myUserProperty = Item.UserProperties.Add("MyPhone", olText)
If Item.Links.Count = 1 Then
Set objContact = Item.Links(1).Item
strBusinessTelephoneNumber = objContact.BusinessTelephoneNumber
strHomeTelephoneNumber = objContact.HomeTelephoneNumber
strMobileTelephoneNumber = objContact.MobileTelephoneNumber
If strBusinessTelephoneNumber <> "" Then
Item.UserProperties("MyPhone") = strBusinessTelephoneNumber
Item.Save
ElseIf strHomeTelephoneNumber <> "" Then
Item.UserProperties("MyPhone") = strHomeTelephoneNumber
Item.Save
ElseIf strMobileTelephoneNumber <> "" Then
Item.UserProperties("MyPhone") = strMobileTelephoneNumber
Item.Save
Set objContact = Nothing
This:
says if the number is not blank, to use it.
I'll have to double check, but i don't think you can get the number dialed - the dialer is not exposed in the object model - but that is what you would need to grab to get the correct number. Or maybe check to see if other numbers have entries and ask which one you want to choose.
donwb
Thanks for your reply.
Could you please clarify this part of your answer:-
"Or maybe check to see if other numbers have entries and ask which one you want to choose."
also, when you say:-
"but I don't think you can get the number dialed"
I presume you mean that even if I dial Mobile, Outlook defaults to Business for entry in Journal. If that's so, what would be the criteria for choosing this default?
Kind Regards
donwb
You could do something like the following (for example only, the code is not complete :))
if mobile <>"" then
inputbox ("which number do you want to use?")
' more code
end if
When you use the dialer, Outlook can't detect which number you are dialing, only who you are calling. It can grab all of the numbers and anything field in the contact, but it doesn't know which number you actually selected in the call dialog.
donwb
Thanks Diane
As Outlook can't detect which number I'm dialing, then there's nothing more I can do.
I will put Business and Mobile numbers into separate Contact entries.
Regards
donwb
I'd probably use an if statement to check - it will require input from you though, where separate contacts won't.
dim caller as string then change your code like this - after the call, you need to press b, h, or m and it will use the correct number. You could make it a little more complicated by checking numbers and if there is only 1, use it instead of asking which one to use.
caller = InputBox("Which number?")
If caller = "b" Then
Item.Save
ElseIf caller = "h" Then
Item.Save
ElseIf caller = "m" Then
Item.Save
This checks to see if either biz or mobile is empty and if so, use the field that has a number. if both have number, it asks which to use
 If strBusinessTelephoneNumber = "" Or strMobileTelephoneNumber = "" Then
      Item.Save
   Item.Save
Item.Save
Item.Save
Item.Save
donwb
Many thanks for the code. I'll try it shortly & let you know the result.
donwb
J What are .PST.db and .PST.db.journal Files? Using Outlook 2
J "Contact" button in Journal entry Using Outlook 1
I "diary or "journal" in Calendar Using Outlook 1
F I want to migrate Outlook journal to excel including contact names Using Outlook 10
E delete journal folder Using Outlook 2
gavin davis Journal and tasks Using Outlook 1
D How to show just the date in an Outlook 2010 Journal view Using Outlook 1
T Contact Field Data not showing in Journal Entry List Using Outlook 4
D Journal to show Phone Number dialled. Using Outlook 3
J Outlook replacement options - contact journal activities lost Using Outlook 23
G calls to journal Using Outlook 2
R Missing outloook journal entry pop up windows Using Outlook 13
M Sync Outlook 2010 Notes and Journal with iPhone 4 Using Outlook 1
B Are their other Outlook Journal entry forms besides the standard? Outlook VBA and Custom Forms 1
M Fixing broken Journal links to Contacts in Outlook 2007 Outlook VBA and Custom Forms 3
S Problem Accessing .MSG Property 'ImageNaturalHeight' Tag '0x80010003' Outlook VBA and Custom Forms 0
