Sent Items not holding Newest on Top
klb
Exchange Server 2010
I have a user who clicks on Sent Items and 50% of the time the list will begin with emails dated "approximately" six months ago, even though the view is set for Arranged by Date Newest on Top. There does not appear to be a pattern as to when this will happen. 50% of the time he opens the Sent Items and the most current is at the top of the list. Why does this happen?
Yes, we have tried changing the view, did not see the problem reoccur in a different view, but the user wants the normal list view and changed it back fairly quickly. It only occurs about 50% of the time and when it occurs, initially the other sent items which occurred "after" the six months old date are not visible. If we click several times back and forth between the Inbox and the Sent items, the view will eventually reset itself back to normal and we can see the more recent Sent items.
It sounds like it's definitely a corrupt view. Is the user using a customized view? Have you Reset the view (View tab > Reset View).
If the user doesn't have custom views, try restarting Outlook using the /cleanviews switch.
icacream Outlook 2021 Win 10 - Nothing goes in my Drafts or Sent items folders ! Using Outlook 1
J Names in sent items suddenly show as Bob Smith (bobsmith@sample.com) Using Outlook 3
M Messages Intermittently Dont Arrive In Sent Items After Sending Successfully Using Outlook 4
D Outlook 2016 Outlook not saving Sent Items Using Outlook 4
D Mail in Sent Items Gone Using Outlook 12
GregS Outlook 2016 Sent Mail absent from Sent Mail or Sent Items Folders Using Outlook 4
J Outlook Reply > From > Other Email Address... > Address Not Showing in Sent Items... From Email Outlook VBA and Custom Forms 0
GregS Outlook 2016 Sent Items vs Sent Messages Using Outlook 2
M Sent mail not showing in Sent Items folder; but they can be found with Search Using Outlook 3
V Items missing in Sent folder Using Outlook 10
M Sent Items Folder is Present but Not Displayed Using Outlook 2
Diane Poremsky Mark Sent Items as Read After Copying with a Rule Using Outlook 0
P Sent items folder vs sent folder Using Outlook 1
Diane Poremsky Display the Recipient Email Address in the Sent Items Folder Using Outlook 0
Diane Poremsky Save Sent Items in Shared Mailbox using an Exchange Server Cmdlet Using Outlook 0
S HOW CAN I CHANGE THIS TO SENT ITEMS Outlook VBA and Custom Forms 3
M Email Appearance in Sent Items Folder Using Outlook 1
M Move Sent Items from server folder to personal folder Using Outlook 2
F Get details of sent items with Access VBA Outlook VBA and Custom Forms 1
S categorizing and Filing sent mail items Outlook VBA and Custom Forms 2
J VBA to copy sent items to folder Outlook VBA and Custom Forms 3
G Macro to move sent items from local folder to IMAP folder Using Outlook 4
R Move sent items emails to hard disk Using Outlook 10
T From Field Blank when saving to folder other than Sent items Using Outlook 2
J Rule to put ONLY sent items in specific folder Using Outlook 1
L Outlook sent items. (email) Using Outlook 2
O Outlook 2013 using DAMO (connector for Domino) Sent Items Issue Using Outlook 2
T Message not arriving in default accounts Sent Items folder when using Send to Using Outlook 2
V Archiving Sent Items Using Outlook 1
O New to Outlook 2013, dealing with copying vs. moving sent items Using Outlook 0
J sent email not reflected on sent items Using Outlook 1
R View who sent on behalf of a shared mailbox in Outlook sent items Using Outlook 1
P move mails after send to central mailbox-sent items folder Using Outlook 4
T Sent Items Rule and Client Only Using Outlook 5
B Can't see Sent Items folder in OL 2010 Imap Using Outlook 1
V Outlook 2010 IMAP Sent Items some items appear in Outlook Data File Using Outlook 3
G Nothing in 'Sent Items' folder in Outlook 2010 Using Outlook 5
B Outlook 2k3 with Exchange: Browsing Sent items without downloading? Using Outlook 2
C Print all emails in a single folder with sent items Using Outlook 2
G Sent Items Using Outlook 5
G Manually created Sent Items folder is lost Using Outlook 4
H Sent emails end up in duplicate in Sent items folder Using Outlook 13
J Sent Items Outlook VBA and Custom Forms 12
T POP Sent Folder Synchronization Issue & Inbox Email Date Display Disorder Using Outlook 2
A Outlook 365 Can I set up a Microsoft 365 account to capture emails sent and received from a comcast.net account? Using Outlook 7
