Need clarification on 2-Step Verification for Gmail using Outlook 2021
Post number 10 has been selected as the best answer.
e_a_g_l_e_p_i
When I first got Outlook 2021 I remember having to setup 2-Step Verification so Gmail would work with Outlook 2021. At that time I also had another Google product that I was able to sign in just with email and password. About 10 days ago I had to do a fresh install of Windows 10 and of course reinstall all my software. I had to setup Outlook 2021 again but since I had already setup 2-Step Verification when I first installed it, I just had to get the one time password and everything worked fine. Now I notice that the other Google product is making me do the 2-Step Verification every time I use it. I get a notification that I will get a text message and I have to fill in the G- number code.
I'm being told by Google how to turn off 2-Step Verification which I know how already but my concern is if I turn it off will it mess up my Outlook ??? If I remember correctly 2-Step Verification was a big deal to get Outlook 2021 to work with Gmail.
Is the account in Outlook as pop or imap? If imap, I don't think you need 2 step on (definitely not in Outlook subscription - I thought 2019 and 2021 was the same) - it should bring up the Gmail signin page. POP requires 2 step and an app password.
This should only happen if the authentication isn't saved. what product are you using?
The account is POP, when I original set it up I had to setup 2 Step and had to get a one time password to make it work. The other Google account I mentioned that has changed this time is seeing that my Gmail is 2 step so it's making me do 2 step for every Google account linked to that original Gmail email. If I have to have 2 step for POP there is no fix for this that I can see.
The product I am using is YouTube TV, it never used to ask me for the G- code every time I sign in like it does now and my Gmail account was always setup as POP with 2 step. This all changed when I did a fresh install of Win 10 and had to install everything again.
Here are my notes on setting-up my Gmail Account in Office 2021/Outlook 2021 .
John Doe
John.Doe@gmail.com
Account Type: POP3
pop3: pop.gmail.com
smtp: smtp.gmail.com
login: john.doe@gmail.com
pass: jldjhjkwprpuhbvadljcxvf
- After 2-Step Verification is now enabled, created in main Google Account/Security (not Gmail Settings).
Outgoing server (SMTP) requires Authentication
- Use same settings as my Incoming mail server
Ports (POP3): 995
- This server requires an encrypted connection (SSL/TLS)
Ports (SMTP): 587
- Use the following encrypted connection: STARTTLS
Delivery: (nothing selected)
Notes: See Gmail Notes below.
Gmail Notes:
- You can use either IMAP or POP3 (in email client) to access your Gmail account . You can allow either or both in gmail.com Settings. I have both Enabled. On mobile devices (iPhone and iPad) I use IMAP. As you know, that's a complete copy of everything in the account (including old emails). Works fine for that. But I don't think I need a whole copy of what's up there stuck in my Outlook PST file (it's big enough already), so I use POP3 in Outlook (and only keep the important emails that come in).
- If you send an email to yourself in Outlook (through the Outlook Account you have setup for Gmail) it shows in Inbox AND Sent Items, in both Outlook and Gmail.com (pretty cool).
- Since Outlook is considered "Less Secure" , in main Google Account Settings / Security (not gmail.com Settings) you must set "Less Secure App Access" to ON. Requires login using Secure Password Auth. (SPA)
- At one time Gmail Account was working without an App Password and I had 2-Step verification OFF. But now, 2-Step Verification is Enabled, and you create this password in main Google Account/Security (not Gmail Settings)
- So, for my iPhone and iPad, this gmail account seems to work as IMAP, but in my desktop Outlook-2016, more like POP3.
- Less secure apps & your Google Account - Google Account Help
In 6-2022, Diane Poremsky suggests:
You need to use an app password with POP accounts - in all versions of Outlook - as they won't ask for the second factor.
You set-that-up in Google Security (not Gmail Settings).
Be sure to enter the App Password properly (into Outlook Password field).
Yes I know, I setup my Outlook 2021 and it works fine, it's just now when I sign in to my YouTube using my Gmail account I have to keep doing the 2 step. I realize this is an Outlook forum but clearly something in the settings of my Gmail account is causing this. hoping maybe someone has an idea??
Browser, Same thing happens in both Chrome and Firefox. The problem is related to my Gmail since that is what I use to login to YouTube TV. My questions is I setup Gmail for Outlook over a year ago and I didn't have this problem at all. When I did the fresh install of Win 10 I had to install everything again, somehow because I have 2 step for my Gmail enabled because I chose to use POP, Now it affects my login to YouTube TV when it never has in the past??
Not blocking cookies
I don't stay logged into my Profile, when I am trying to login to YouTube TV I am logging into my Gmail account
Not sure what you mean by "security settings" can you be more specific please
I just wanted to update everyone.
First of all thanks for those who tried to help me. This wasn't a Outlook issue obviously but since it had to do with 2 step and since I had to enable 2 step to use Outlook 2021 with Gmail I thought I would give it a shot on here.
It turns out that the issue was with cookies, I have a program that cleans everything whenever I close a browser, since it clears the cookies that is why Google was making me go through 2 step for YouTube Tv. In the program I just added YouTube TV to a list of cookies that are not cleared on exit and that fixed the issue.
Thanks again, you could have simply said "This is not an Outlook issue, Contact YouTube TV " but you didn't you tried to help me, and I appreciate it!!
Yes, when I installed Outlook 2021 ( which isn't a subscription, I bought Office 2021 ) I remembered you saying that using Outlook 2021 and Gmail I had o use 2 step and go to Google account and create a one time password using their app.
Since I first installed Office 2021 and linked my Gmail account to use Outlook I have had 2 step setup. I've also have other Gmail accounts and use YouTube TV but never did Google make me use 2 step on them when I logged in, I just had to use my Gmail and password and was able to login. After I did a reinstall of Win 10 about 3 weeks ago and installed Outlook 2021 as part of Office 2021 now I have to use 2 step for any Google account??? it doesn't make sense to me I didn't change any settings, 2 step for my Gmail that I use for Outlook 2021 was still enabled so I didn't have to do anything when I did the fresh install.
So I have no idea why Google is now making me use 2 step for all Google accounts??? You last post you asked me about security settings and I told you I wasn't sure what you meant, you never replied?
macdotcom Outlook 365 Outlook folder export to PST archival tool - close, but need a nudge Outlook VBA and Custom Forms 2
P OT: Need website like this one, but for Excel Using Outlook 0
A Wishlist Arthur workman I need the community's assistance thank you Using Outlook 3
A from Arthur to anyone I need your expertise assistance Using Outlook.com accounts in Outlook 7
L Need to import multiple Outlook files to Office 365 Account Using Outlook 4
Horsepower Need iCloud mail only Using Outlook 1
O Don't need any add-ins at all? Using Outlook 2
A Need to view Outlook calendar in Sharepoint .. Using Outlook 2
L Accidentally merged a calendar with .ics, need to undo! Using Outlook 1
D Need Genuine Office or Outlook 2007 Using Outlook 3
G how to cancel a recurring meeting but not the organizer but all attendees need to know. Using Outlook 1
N Need a case sensitive rule Outlook VBA and Custom Forms 1
C Need rule to alert when an email has not been replied to within 24 hours Using Outlook 1
F Outbox - Multiple Emails need to be manually opened? Using Outlook 5
Miquela I need to make a calendar to share here at work with 40 other people Using Outlook 1
S Need CC: to show the original To: recip[ients Using Outlook 4
D Need to extract a line from a word attachment, and add it to the subject line Outlook VBA and Custom Forms 3
mikecox Desperat; need hands on support Using Outlook 1
Glyn Do I Need Outlook.com Using Outlook 1
