Need replacement for iTunes to locally (USB) sync. iPhone 17 to Classic Outlook 2024
JimBob
Outlook 2013 32 bit
Operating system::    Win11 Pro 24H2
Outlook version:     Classic Outlook 2024
Email type or host:    several accounts - all are POP
I searched the old threads, and had to go back a long way to find anything on sync-ing... so I thought I'd start fresh
I've been using iTunes to sync. to my Classic Outlook calendar & Contacts via a USB connection since I had an iPhone 3s,
but Apple is moving away from iTunes and sync. is no longer supported.
The replacement for iTunes - Apple Devices does not support sync. as far as I can tell.
From a scan of 3rd party s/w it seems there are two options for local/usb sync:
CompanionLink & AkrutoSync
CompanionLink syncs to an app that has to be installed - DejaOffice and then from there contacts and calendar can be further sync-ed to the native Apple apps.
AkrutoSync - syncs using a (I'll call it) a dummy Exchange server style connection. All contacts on the iPhone have to be blown away during setup.
This is a bit of an issue for me as my contacts are currently out of sync.
I know @Diane Poremsky (at least was) more fond of CompanionLink and they are an advertiser here on Slipstick.
Are there any other programs I should consider?
Any reason to NOT go with CompanionLink?
Jim
You definitely can only use usb? If so, those are the options. Both should have trials. It's been while since I used akruto so I forget what all it does and can't say offhand if it's better than companionlink .
If you can sync over the Internet, gsyncit syncs to iCloud (google, yahoo and more).
Thank you very much @Diane Poremsky
I travel quite a bit in the 3rd world where internet speeds are 3-5 Mb and besides being painfully slow ... are unreliable.
I'll give companionlink a go and see if it works! If not I'll try Akruto if not.
I'll report back with the results!
I really really appreciate you!
Jim
macdotcom Outlook 365 Outlook folder export to PST archival tool - close, but need a nudge Outlook VBA and Custom Forms 2
P OT: Need website like this one, but for Excel Using Outlook 0
A Wishlist Arthur workman I need the community's assistance thank you Using Outlook 3
A from Arthur to anyone I need your expertise assistance Using Outlook.com accounts in Outlook 7
L Need to import multiple Outlook files to Office 365 Account Using Outlook 4
Horsepower Need iCloud mail only Using Outlook 1
O Don't need any add-ins at all? Using Outlook 2
A Need to view Outlook calendar in Sharepoint .. Using Outlook 2
L Accidentally merged a calendar with .ics, need to undo! Using Outlook 1
D Need Genuine Office or Outlook 2007 Using Outlook 3
G how to cancel a recurring meeting but not the organizer but all attendees need to know. Using Outlook 1
N Need a case sensitive rule Outlook VBA and Custom Forms 1
C Need rule to alert when an email has not been replied to within 24 hours Using Outlook 1
F Outbox - Multiple Emails need to be manually opened? Using Outlook 5
Miquela I need to make a calendar to share here at work with 40 other people Using Outlook 1
S Need CC: to show the original To: recip[ients Using Outlook 4
D Need to extract a line from a word attachment, and add it to the subject line Outlook VBA and Custom Forms 3
mikecox Desperat; need hands on support Using Outlook 1
