Outlook problem with IMAP
  • Thread starter Thread starter Thoroughbred
Thoroughbred
I have just purchased a new computer which has Windows Vista as the OS.
I have set up my main email addresses and they work fine both sending and
receiving emails. However I am having a problem with the imap settings on my
AOL account.
Having now installed Office and 'copied' the settings that were on my old
computer [which had XP as the OS] I am receiving the following error message:
Task 'synchronizing subscribed folders for reported error' (0x8004005)
Outlook cannot synchronize sunscribed folders if you continue to receive this
message please contcat your server administrator or ISP.
The settings for the incoming mail server are imap.aol.com for outgoing is
smtp.aol.com the account type is imap. The outgoing server requires
authentication and is ticked accordingly. Incoming port is 143 and outgoing
is 587 with encrypted connection as TLS.
What am I doing wrong or what do I need to do in-order for the folders to
synchronize and for my mail to come down to the folders?
Thanks, TB
"Thoroughbred" <Thoroughbred> wrote in message
news:02A8A6BC-3B48-4DAB-9354-98A6680C5BBD@microsoft.com...
> AOL account.
> message:
> this
Outlook version? See of this helps:
http://www.howto-outlook.com/howto/accountsettings.htm#aol
Hi Brian,
Thank you for your reply.
I am using Outlook 2007. I have tried all combinations that are on that
page. When I first set up the 'new' account in Oulook it works fine with the
settings that I quoted in my first post. It is only when I close Outlook
down and re-open it later that I get the problem and nothing downloads and
the 'synchronizing subscribed folders for reported error' (0x8004005) shows.
> > AOL account.
> > message:
> > this
news:D0D42415-8CE6-48E7-A03C-BA10EFCCD265@microsoft.com...
> page.
I'm afraid I'm at a loss, then. Perhaps someone else will be able to suggest
something.
> page.
I did think of something more thing to try. Start Outlook is safe mode (hold
Ctrl when starting it) and see if that makes a difference. With Outlook
clised, delete the SRS file in the (usually hidden) folder
%AppData%\Microsoft\Outlook and see if that changes anything.
(hold
The folders download and update fine when in safe mode.
As soon as I restart Outlook normally I receive the error message again and
it cannot synch.
I deleted the SRS file and this made no difference
news:CC144428-4243-414F-AB9E-317854E71F4E@microsoft.com...
Disable all of your add-ins and enable them one at a time to see if you can
find what's causing the problem. If you have an antivirus program configured
to scan your mail, uninstall it and reinstall it wihtout the mail scanning
feature.
"> Disable all of your add-ins and enable them one at a time to see if you can
> feature.
Brian you are a star! Thank you. The problem has been resolved when I
switched off the spamguard filter. Cheers. Jim
I think I finally found a solution to the problem. In Outlook 2010, go to files, options, advanced, send and receive and click on the send and receive edit button. From there, click on the edit button to all accounts. In the send/receive settings – all accounts, about halfway down the page change your options for receive mail items to: "use the custom behavior defined below". From there each of the folders you want to sync from your AOL account into your outlook account noting along the way that you can choose between download headers only or download complete item including attachments. Click okay. You're done!
Thanks, this worked and solved my problem. AOL wanted to charge me $129 for a techie to connect with me and fix it. I said no way. Your solution was simple and easy to follow. Thanks again.
Your welcome. Mark
Marc2019 Outlook 2016 Font Problem Using Outlook 4
X Problem Transferring Subset of Outlook 2013 Contacts to iPad/iPhone Using Outlook 5
K Outlook(hotmail)Yahoo problem Using Outlook 6
N Outlook 2013 and Surface RT synchronisation problem Using Outlook 3
F Outlook group by conversation problem Using Outlook 1
J it goes like outlook has stopped working, a problem caused the program to stop working correctly, wi Using Outlook 2
T Problem With Mail Setup IN Outlook 2013 Using Outlook 2
C Outlook problem Using Outlook 9
P problem with set up group by conversation in outlook 2010 Using Outlook 3
L Outlook DST (Daylight Saving Time) problem Using Outlook 0
D Problem with MS mail and outlook 2007 OS Windows 8 Using Outlook 1
M Outlook synchronisation problem (Error : 80041003) Using Outlook 0
S Problem syncing mail from a POP3 account in Outlook 2013 to iphone 5 Using Outlook 1
A Problem sync group goole calendar with outlook 2001 Using Outlook 0
J outlook problem it allow to book meeting room at the same day & time Using Outlook 0
B Outlook network password problem. Using Outlook 0
L Problem with Outlook 2007 with windows 7 Using Outlook 0
D Icloud Outlook 2010 Task/Reminder Search Problem Using Outlook 1
V New problem, .oft extentions in Outlook 2013 Using Outlook 5
W Outlook Stationary Font Formating Problem Using Outlook 7
K Outlook 2010 - sending pdf about 8 MB problem Using Outlook 2
J My Headset problem when Dialing Out from Outlook Contacts Using Outlook 1
C Problem with Outlook truncating images Using Outlook 6
W New Problem using Outlook over network Using Outlook 1
H Downloading Outlook 2010 from Volume Licensing Centre problem Using Outlook 1
M Outlook 2010 Custom Form Problem Using Outlook 1
