Create/Apply auto formatting rules by VB?
  • Thread starter Thread starter Heinz-Josef Bomanns
H
Heinz-Josef Bomanns
with auto formatting i can tell Outlook to show entries in explorer
tables in for eg. bold, colorized, underlined etc. based on some
criterias. Just wondering if it's possible to create/apply auto
formatting rules by VB? I had a look at the View.XML property, but
auto formatting rules seems to be stored elsewhere. Anybody knows
where auto formatting rules are stored or can be created/applied by
code? Thanks for any hints...
So long...
> ..Bomi
> !!! In case you want to reply via email please use Reply-To address and remove underscores (_) !!!
Autoformatting rules are not exposed by View.XML. You can access them only in
Outlook 2007, through the AutoFormatRules collection for the TableView and
other view objects. Changes made to AutoFormatRules do not persist between
Outlook sessions.
Sue Mosher
"Heinz-Josef Bomanns" wrote:
> Hi,
Hallo Sue,
> Outlook sessions.
Thanks, will give it a try in 2007...
So long...
> ..Bomi
T Create a group from a large To distribution list Using Outlook 3
