Get AutoArchive settings (as set from Tools|Options|Other|AutoArch
  • Thread starter Thread starter ron podl
ron podl
Is there a way to get the default AutoArchive settings using the Outlook
(2007) object model using VB (VS2008)?
I want to programmatically determine where each outlook folder and
subfolders are being autoarchived to.
With the following:
Dim si As StorageItem = oFolder.GetStorage("IPC.MS.Outlook.AgingProperties",
2) 'olIdentifyByMessageClass)
Dim PA As PropertyAccessor = si.PropertyAccessor
and with this and some other properties and logic
Const PR_AGING_FILE_NAME_AFTER9 = _
"http://schemas.microsoft.com/mapi/proptag/0x6859001E"
dim fname as string = PA.GetProperty(PR_AGING_FILE_NAME_AFTER9)
I can tell if a specific folder is being archived to the default AutoArchive
pst file as set in the Tools|Options|Other|AutoArchive dialog or to a
different pst file for that folder.
But I don't see how to get the filename (or other settings) set in the
Tools|Options|Other|AutoArchive dialog. Is it possible?
thanks
ron
Some of the settings are stored in the registry under the
HKCU\Software\Microsoft\Office\12.0\Preferences key (12.0 is Outlook 2007
specific). Other settings are stored on an Outlook profile specific basis,
also in the registry. Look at http://support.microsoft.com/kb/198479.
"ron podl" <ronpodl> wrote in message
news:96D699A2-845C-48D3-9CBA-9B2965AFAC7B@microsoft.com...
> With the following:
> AutoArchive
> thanks
> ron
E Moving autoarchive settings to new computer (Outlook 2007) Using Outlook 1
K Revert AutoArchive settings via GPO (Run Autoarchive every...) Using Outlook 4
B Update AutoArchive Settings on Multiple PST Files Outlook VBA and Custom Forms 5
A Autoarchive questions Using Outlook 2
Victor_50 Set all subfolders to not autoarchive Outlook VBA and Custom Forms 11
Diane Poremsky Using Outlook's AutoArchive Feature Using Outlook 0
B AutoArchive Nuances Using Outlook 1
M Can't change autoarchive property in Deleted Items folder BCM (Business Contact Manager) 1
R Roadrunner Email Settings | Contact Roadrunner Customer Support Outlook VBA and Custom Forms 0
HarvMan Outlook 365 loses "outlook.com" exchange server settings Using Outlook 1
L Recommendations for Utility to Backup Outlook 365 Account Settings Using Outlook 2
G Personal Settings within Outlook Using Outlook 2
David Langer Store my Outlook settings in the cloud - Broken Using Outlook 4
T Migrating Profile/Account Settings To New PC for Outlook 2016 Using Outlook 2
O Backup Office settings - registry key Using Outlook 5
S Views ans Where Settings AreSavd Using Outlook 4
J Control Panel Mail (settings) icon missing Using Outlook 2
GregS "Your <mail provider> settings are out of date" Using Outlook 0
Commander1 Task Recurrence Settings Using Outlook 3
M Change default "automatically test account settings when Next is clicked" Using Outlook 1
F Missing "More Settings" in Outlook 2007 Professional Using Outlook 8
A Help creating macro for conditional formatting settings Using Outlook 8
L changing view settings based on message body Using Outlook 1
B Email address not showing up in account settings Using Outlook 3
B Outlook 2007 Save Current View,Font,Toolbar Settings Using Outlook 6
T save custom user settings/ views BCM (Business Contact Manager) 2
S Oulook view settings ( NO PST) Using Outlook 0
wallisellener BCM - restore default settings BCM (Business Contact Manager) 36
T Settings question Using Outlook 6
O Outlook 2013 not holding bottom navigation settings Using Outlook 10
H PRF with OverwriteProfile=Append Is overwriting other settings Using Outlook 2
I Reconfigure standard Outlook settings on all machines Using Outlook 0
E "Current View" settings across multiple users on same Exchange 2007 account. Using Outlook 1
M authentication settings for outlook for mac 2011 Using Outlook 1
