Multiple Calendars issue - how to delete?
abailes
I have a large amount of old e-mails stored in about 20 different data files within Outlook 2010. I'm a very heavy user of Outlook and file away well over 100 messages a day. I need to for legal reasons. Most of these data files are well over 1Gb each.
Recently I tried to install a auto-filing application (wolf something or other) and, before I could stop it, it added a additional set of folders into each and every data file. Specifically, it added a Drafts Folder, a Junk E-mail folder, an RSS Feeds folder, a Calendar folder, a Contacts Folder, a Journal Folder, a Notes Folder and a Tasks folder to every one of my 20 data files. As the damn software didn't work, I am still filing manually, but now my life is significantly harder as I have about 20 x 10 = 200 additional, empty, folders to scroll through.
Furthermore, in the Calendar application, I now have 20 calendars to contend with, whereas I need and use only one (in my main mailbox).
And of course, I cannot delete these folders as you cannot delete a Calendar folder, etc. etc. That option is grayed out from the right-click menu.
There must be a way to delete these... please help, its driving me spare.
Yes, I probably could set up 20 new data files and drag everything across, but given the size of everything, that would take me probably a day to sort out.
Any assistance very much appreciated.
Many thanks.
yikes, the program made the pst files think they were the defaults (or it treated each as the default) and created the default folder. I'd try MFCMAPI to delete the extra folders - get it from mfcmapi.codeplex.com. If you need help using it, the articles here; http://www.outlook-tips.net/?s=mfcmapi should get you pointed in the right direction. If you still need help, i'll write up the exact instructions in the morning.
J Multiple calendars Using Outlook 0
V Multiple Calendars in Outlook To-Do Bar; Office 365 Using Outlook 3
Diane Poremsky Combine and Print Multiple Outlook Calendars Using Outlook 0
Jeanne Goodman Create Printout from Multiple Shared Calendars Outlook VBA and Custom Forms 8
Diane Poremsky Select Multiple Calendars in Outlook Using Outlook 0
T populating multiple calendars without invites Using Outlook 1
ACM Viewing Outlook calendars on multiple devices Using Outlook 3
V Cannot search multiple calendars at once Using Outlook 2
B Sharing Multiple Outlook 2010 Calendars (Exchange) Exchange Server Administration 4
M syning multiple calendars from Outlook 2007 through iTunes Using Outlook 3
P Print multiple pocket calendars on one page Using Outlook 5
M How do I get Outlook Today to show appts from multiple calendars? Using Outlook 5
A Know any product to sync multiple Exchange calendars please? Using Outlook 4
H running multiple macros at once Outlook VBA and Custom Forms 0
chummy Open multiple Hyperlinks to download files Outlook VBA and Custom Forms 3
R Select Multiple Graphic Objects Using Outlook 0
Hornblower409 Automatically or Manually Backup Multiple Versions of VbaProject.OTM Outlook VBA and Custom Forms 1
C Outlook 365 Multiple different Signatures on Shared Mailbox Using Outlook 0
D multiple email accounts - why do I have to choose the "from" account address?? Using Outlook 2
C How to search for items in Outbox with multiple accounts? Using Outlook 20
K How to share multiple calendar items Using Outlook 1
K Multiple copies of task being created Using Outlook 2
K Multiple Rules on Single Email Using Outlook 2
Cathy Rhone gmail listed multiple times Using Outlook 3
V Outlook 2016 Multiple recurring tasks getting created Using Outlook 0
C Multiple emails Using Outlook 8
A Multiple signatures Using Outlook 2
L Multiple Inboxes Using Outlook 3
RBLampert Accessing Outlook accounts from multiple computers Using Outlook 8
Martull Forced signature when multiple accounts exist Outlook VBA and Custom Forms 4
papa.deblanc Multiple Instances Using Outlook 6
