Outlook will send but not receive
Newt
It did this one time in the past. I don't recall the fix. It happens after trying to send too large a jpeg file in an email.
This is using Outlook Connector and Hotmail.
Errors :
Time: 5/25/2011 5:21:17 PM
Error in Mail
Network operation failed
Time: 5/25/2011 5:21:18 PM
Error in Mail
Error with Send/Receive.
There was an error synchronizing your folder hierarchy.The network connection is unavailable or interrupted. Please try again later.
Newt
You need to move the large mail to a local folder (ie, in a pst in your profile). If you delete it, you need to use Shift+Delete to hard delete it.
Check online to see if the message synced, if it did, delete it from online too.
The deleted folders in both Outlook & Hotmail have been deleted.
Outlook is just sitting there. Showing under server status: Mail: connecting, Calendar: connecting, Contacts: connecting.
Newt
have you tried a new profile? You could remove the account from your profile and re-add it, but if you have any tasks or notes, you'll need ot copy them to a local pst first - a new profile will allow us to see if it works without risking the lost of notes and tasks or anything else that hasn't synced up.
Create the profile in Control panel - search for mail then profiles.
We have a tutorial here if you need it: http://www.slipstick.com/outlook/how-to-create-a-new-profile/
P Removing Outlook 365 Account from Send/Receive Using Outlook 3
Diane Poremsky Configuring a Manual Send and Receive in Outlook Using Outlook 0
P Outlook 2007 not sending/receiving until restart (send/receive stuck at __%) Using Outlook 27
S send/receive issues outlook 2013 Using Outlook 4
W OUTLOOK 2007 FREEZES. WILL NOT SEND NOR RECEIVE Using Outlook 1
wisedave Office 365 Outlook - Emails send but don't receive Using Outlook 12
D Outlook 2010 hangs during message send/receive Using Outlook 2
N Outlook 2010 take long time in send / receive Using Outlook 1
A Auto send-receive in Outlook not working Using Outlook 6
D Emails stuck in Outbox, not receiving emails, Outlook 2010 auto send/receive Using Outlook 4
T Outlook 2010 manually actioning of send and receive? remove auto actioning Using Outlook 4
P Send/Receive error in Outlook 2007 Using Outlook 2
S Connector Forces Outlook 2007 To Hang On Send/Receive Using Outlook.com accounts in Outlook 3
B Send/Receive Status in Outlook 2010 Using Outlook 2
T Outlook Error synchronizing your folder hierarchy : 80041050. Send Not Receive Using Outlook.com accounts in Outlook 6
A Outlook 2010 - can't send/receive data file cannot be accessed Using Outlook 10
A Send/Receive while outlook closed? Outlook VBA and Custom Forms 18
Q Outlook Macro to do a send/receive on specific group Outlook VBA and Custom Forms 1
M Outlook 365 refuses to send email Using Outlook 0
F Send As a Gmail account via outlook Web Using Outlook 3
M Can't send email in outlook.com Using Outlook 9
R Can't send messages to groups in Outlook Using Outlook 2
soadfan Outlook won't send e-mail when offline Outlook VBA and Custom Forms 19
D Outlook.com in Outlook 2016 Trys & Fails to Send on Behalf of Itself Using Outlook.com accounts in Outlook 2
D send email from Excel using outlook template Outlook VBA and Custom Forms 3
E How to send automatic emails in outlook 2010 Using Outlook 1
P Send mails by Gmail not shown in outlook Using Outlook 5
C Unchecking "Send immediately when connected" does not work on apps that call Outlook Using Outlook 1
T Can't send email through connected account (outlook.live.com) - goes to Drafts folder Using Outlook.com accounts in Outlook 3
Tim King Send mail from MSWord through Outlook Using Outlook 3
