Meeting organizer incorrect
rich872
I've got a user is trying to delete a recurring meeting off of her calendar but the meeting is showing her as the organizer when in fact the organizer is someone else. So if she deletes the meeting it would delete it off of everyone else's calendar. I've checked the other users calendars that are on the meeting and it does list another user as the organizer of the meeting. Has anyone seen this before or know how to correct it?
rich872
Thank you for your suggestion. I had the user delete the meeting request which did in fact delete it off of everyone else's calendar and then I had the real organizer recreate it. But your suggestion sounds like the way to got where I could have avoided the original owner recreate it. I found the below from MS about this issue fyi:
Microsoft has this issue documented in the following Knowledge Base article. Basically, your only recourse is to delete the damaged meeting from the affected user's calendar, and patch the Exchange Server to the referenced patch level for Exchange 2007 to prevent future issues.
Issue 1.2 - Attendee becomes meeting organizer
When you synchronize your iOS or Android device by using Exchange ActiveSync on an Exchange Server 2007 mailbox, you may unexpectedly become the organizer for a meeting that you were invited to. This does not change the meeting for all attendees.
Solution
This can occur if you change the reminder for a single occurrence of a recurring meeting on an iOS or Android device. There may be other property changes to meeting items that may result in the same symptom.
This issue is resolved in Rollup Update 4 for Exchange Server 2007 Service Pack 3. See the KB article below for additional information.
2521063 You are incorrectly displayed as a meeting organizer after you synchronize the meeting by using your mobile device in an Exchange Server 2007 environment
Note Affected meetings must be deleted and replacement meetings must be created after the servers are patched.
http://support.microsoft.com/kb/2563324
correct, to restore the rightful owner you need to recreate the meetings - the patch won't undo the damage.
D Outlook 365 Forward Meeting Related Messages to Specific Meeting Organizer Outlook VBA and Custom Forms 0
A Meeting organizer calendar intermittently drops meeting after delegate sends invite Using Outlook 0
A Meeting organizer calendar intermittently drops meeting after delegate sends invite Exchange Server Administration 0
J Outlook 2016 shows Meeting Organizer in Calendar View Using Outlook 5
G how to cancel a recurring meeting but not the organizer but all attendees need to know. Using Outlook 1
P Viewing Meeting Organizer on room Mailbox Using Outlook 1
Simon How does the sender/organizer to dictate the color of a meeting invitation. Using Outlook 3
R Why is a meeting organizer me and not the creator of the event? Using Outlook 1
M Open meeting in organizer's shared calendar Using Outlook 0
S MAC outlook doesn't show the meeting organizer detail Using Outlook 0
I Does forwarded meeting invite gets sent to all the Attendees and Organizer? Exchange Server Administration 0
B Outlook 2003: Meeting Organizer will be set as always free or busy status Using Outlook 1
T Outlook 2010/Exchange 2003: Meeting Organizer doesn't show Using Outlook 1
O Changing meeting organizer in outlook Using Outlook 3
R Add multiple individuals as meeting organizer Using Outlook 4
J RE: E-mail address of the meeting organizer Outlook VBA and Custom Forms 1
B change meeting organizer of recurring meeting without cancellnig Using Outlook 2
J Event/Meeting in Outlook Does Not Align with SharePoint Calendar Using Outlook 5
S Meeting with Time Slots Using Outlook 2
egarneau Meeting updates with external contacts (GMail) Using Outlook 1
S Meeting Invite arrives from Wrong ("send-as") Sender Using Outlook 1
Daniel Schunk Meeting responses are not shown in the status area Using Outlook 2
A End-time meeting reminder (or "negative" time relative to the meeting start time) Using Outlook 1
T Pick-a-Meeting in Outlook 365 Using Outlook 2
J No response required when delegate arranging meeting Using Outlook 0
S Accepting meeting request from calendar keeps the meeting request in the inbox Using Outlook 2
D Add all meeting rooms to the meeting request by default Outlook VBA and Custom Forms 0
Rick Rickert Would like bigger meeting notifications. Using Outlook 3
D Next Available Meeting with Userform Variables Outlook VBA and Custom Forms 1
C Update Notes for Meeting Attendees Using Outlook 8
P Skype contact icons have disappeared at the bottom of email and meeting objects Using Outlook 2
T Double clik behavior on agenda open a new meeting request Using Outlook 1
B How to get Meeting Invitations into Outlook.com calendar? Using Outlook 2
Diane Poremsky Autoaccept a Meeting Request using Rules Using Outlook 2
Diane Poremsky Close a Meeting When the Room is Full Using Outlook 0
A Attendee Update Outlook Meeting Invite Using Outlook 0
Diane Poremsky iPhone and the Meeting Request Bug Using Outlook 0
P Receiving a Meeting Declined notice for a recurring meeting Using Outlook 0
A Customize meeting form. Private notices Outlook VBA and Custom Forms 3
A VBA to create meeting from template from a time slot selected in someone's calendar Outlook VBA and Custom Forms 5
Diane Poremsky Meeting Location Warning Message Using Outlook 0
