calendar contacts export problem
wazo
hi there, just a little stumped on this unusual problem. a customer has created calendar and contacts in a folder in the inbox of outlook 2010; I want to put them back in the right place in the new install of outlook 2013. do I just export the folder and import back to calendar and contacts (people)? or is there a better approach? the account is a gmail imap
You can either import and drag and drop to the main level.
Because you use imap and outlook 2013 changed how the special folders *calendar etc) are handled, with them in the imap folders, I would create the profile using the control panel applet, add a pst to the profile and set it as default before opening Outlook. Use it for calendar and contacts and the imap folder for mail only.
What you need to know about IMAP accounts in Outlook 2013 - Slipstick Systems
R How to prevent corrupted Notes format in Calendar and Contacts Using Outlook 0
N Gathering Calendar Appointments from Calendars that synced as Contacts Exchange Server Administration 1
W Migrating Outlook 365 Contacts & Calendar Using Outlook 2
S Missing Outlook calendar and contacts Using Outlook 0
Diane Poremsky Sharing Outlook Calendar and Contacts Using Outlook 0
L Entering dates in Contacts and Calendar Using Outlook 4
Diane Poremsky Sharing Outlook Calendar and Contacts over the Internet Using Outlook 0
I iCloud Calendar and Contacts in Outlook 365 Using Outlook.com accounts in Outlook 2
A sync ol13 contacts and calendar with wp 8.1 Using Outlook.com accounts in Outlook 4
N Sync Contacts and Calendar with 2 Windows 8.1 and 1 iPod Touch Using Outlook 9
V Sync Outlook contacts/calendar on two computers using iCloud Using Outlook 2
K How to make use of outlook calendar, contacts & tasks using personal POP3 mail Using Outlook 1
Commodore Access to contacts, calendar, tasks... from 3rd party applications Using Outlook 2
A how to install or enable categories in OL 2013 for calendar and contacts Using Outlook 5
C Lost calendar and contacts to icloud: Help! Using Outlook 1
L Need help getting calendar/contacts/tasks/notes back! Using Outlook 3
M How to set default calendar & contacts Using Outlook 0
V Setting up windows 7 & outlook 2007 w/ Iphone 4 & synch contacts & calendar Using Outlook 9
L Sync Calendar and Contacts Only Using Outlook 1
C Remove iCloud so I can have original outlook calendar and contacts Using Outlook 43
V Sync calendar and contacts using Outlook.com and any LiveID Using Outlook 8
V Sync Outlook contacts and calendar to Android phone Using Outlook 3
M Access replicated Outlook (email folders, calendar, contacts, notes) via web Using Outlook 1
P Created new profile, how do I share existing contacts/calendar? Using Outlook 1
J iCloud Calendar/Contacts Syncing Hangs At End - aplzod Data Store Not Created Using Outlook 8
G Import pst but Calendar and Contacts don't show. Using Outlook 12
R Transferring Contacts, Calendar and Tasks to another computer Using Outlook 0
G Synchronize outlook contacts and calendar with other pc for free Using Outlook 4
G Forms error on iCloud calendar Using Outlook 15
V select default calendar Outlook VBA and Custom Forms 3
M Calendar items have a pale pink blushing Using Outlook 3
T Cannot delete a calendar Using Outlook 0
F Show events in Monthly Calendar Using Outlook 3
