Sync calendar and contacts using Outlook.com and any LiveID
Vincenzo
Outlook 2021 64 bit
Using Outlook 2010 and the Outlook Connector, I've tried Diane's method shown here Sync calendar and contacts using Outlook.com and any LiveID - Slipstick Systems The account gets created in Outlook. When I go to Account Settings/Email tab, it shows up as a MAPI account. But when I go to the Data Files tab, for Location it says "not available". This seems incorrect. And how do I get my calendar and contacts to sync with Hotmail online? The tutorial says "You'll need to move or copy existing appointments and contacts to the new Hotmail data file" but I don't get how to do that. Thanks
I just looked in the Outlook folder in AppData and there is a .ost file that was created. Not sure why Outlook says it is not available. And I still need to figure out how to get the Contacts and Calendar to use it.
"Not available" is correct for the Outlook Connector when Outlook is not running. You should be able to set it as default, if desired. Otherwise, don't worry about it.
After opening Outlook, you can select all in your contacts folder and use the Move to folder command to move the contacts to the Connector's folders. In the Calendar, switch to a list view, then select all and move to the Connector's calendar. See Merging Two Calendar Folders - Slipstick Systems if you need screenshots or a tutorial - the method is the same for any Outlook item, but you will need to use a list view in the Calendar.
OK thanks, I got that working. Can the old Contacts and Calendar be deleted or hidden to ensure that future changes are done in the new Contacts list and Calendar? I am setting this up for someone else, they are not the most savvy user. Do I need to set the new data file as the default to keep the chance of them creating problems at a minimum? Thanks
Regarding getting the info onto the Android phone: in Synchronizing Outlook with a PDA or Smartphone - Slipstick Systems you said "If you have an account with Exchange Active Sync enabled (Gmail, Hotmail, and Exchange server support EAS), you can sync over-the-air. To use EAS, you need to set up the account using the Exchange account option on your device." Do you have a webpage about doing that account setup on the phone? Thanks
I don't have exact instructions for droid because I don't have a droid to verify the steps. I understand that each droid might be different as well and it may only be supported on the newer devices. You need to use m.hotmail.com as the server address.
When you set up the email account you should have a choice of pop, imap, or exchange. Choose Exchange. Enter m.hotmail.com as the server name (for any domain in the Hotmail space - msn, Hotmail, outlook.com, live). I've heard that some people need to use \alias@domain.com format in the username field. If it won't take your address as the username, try leading with a slash.
A sync ol13 contacts and calendar with wp 8.1 Using Outlook.com accounts in Outlook 4
N Sync Contacts and Calendar with 2 Windows 8.1 and 1 iPod Touch Using Outlook 9
V Sync Outlook contacts/calendar on two computers using iCloud Using Outlook 2
L Sync Calendar and Contacts Only Using Outlook 1
V Sync Outlook contacts and calendar to Android phone Using Outlook 3
KeithJB iCloud calendar sync only works one way! Using Outlook 3
A hotmail calendar sync Using Outlook 1
T Outlook 2010 calendar won't sync with Android phone Using Outlook 3
S Sync Outlook 2013 calendar via outlook.com to Android Exchange Server Administration 1
V Any alternative to iCloud for calendar sync to iPhone? Using Outlook 8
F Sync Sharepoint Calendar With Personal Calendar Outlook VBA and Custom Forms 5
T Calendar Entry in Outlook Client but will not sync Exchange Server Administration 1
F sync outlook + outlook.com, calendar sync only 1way, contact sync 2way OK Using Outlook.com accounts in Outlook 1
A Calendar Reminders are Removed with Sync to Outlook.com Using Outlook.com accounts in Outlook 11
C Sync color categories on a Public Calendar across Office 365, PCs, Macs Using Outlook 1
P Sync 2013 calendar between 2 devices -Surface 2 and Desktop using Outlook.com Using Outlook.com accounts in Outlook 8
B iPhone Calendar will not sync with Outlook 2013 Using Outlook 0
T Outlook Calendar Sync MY GOAL: see work calendar on home desktop w/o OWA Using Outlook 2
A Problem sync group goole calendar with outlook 2001 Using Outlook 0
K outlook calendar wont sync iphone 4 Using Outlook 1
E Outlook 2013 calendar won't sync with iphone 4s Using Outlook 14
M sync Outlook 2007 calendar with icloud Using Outlook 1
J Outlook Calendar will not sync with Windows Live.com account Using Outlook 9
V Sync Outlook 2003 calendar to iPhone 4 Using Outlook 2
T Calendar sync off by 1 hour - outlook 2010 / icloud 2.1 / ipad Using Outlook 2
S Using POP3, Exchange server, and iPhone sync - can't sync to POP3 calendar Exchange Server Administration 0
S Copy Events to Second Calendar or Sync Only "Busy" Events Using Outlook 5
L Cannot sync Calendar to iphone. Cannot export to CSV. Cannot view as Table. Using Outlook 3
P Windows Live Calendar sync Outlook Using Outlook.com accounts in Outlook 4
B how do i sync windows live calendar with my Blackberry Using Outlook.com accounts in Outlook 2
T IMAP mail sync is extremely slow Using Outlook 7
S Import pst file into 365 desktop and have it sync one Using Outlook.com accounts in Outlook 2
C reminders not synced by CodeTwo Sync for iCloud Using Outlook 2
P How to clear out all contacts in iCloud, so I can use iCloud-based sync program Using Outlook 1
