Calendar Macro
Got it. Just so you know I already have the getcurrentitem function...so don' need it..I read the following re if a conact is open...
When you are looking at an item that is open and has focus, it uses an
Outlook Inspector. The code you need to work with Inspectors is:
[TD="class: code"]Set objItem = objApp.ActiveInspector.CurrentItem
If that is what needs to be added, where do I put it re the code below that creates the calendar event etc...and anything else to add:
Sub Office_Calendar_Event()
Set myFolder = Session.GetDefaultFolder(olFolderCalendar).Folders ("Office Calendar")
Set myItem = myFolder.Items.Add("IPM.Appointment.Office Calendar Event")
myItem.Display
[/TD]
The following is the code that works to create a calendar event from a contact and in the contact I have the Start and Time controls where I create the date and time and it creates it on the calendar event....But, the controls that I use on the contact, do not save the date and time to the controls on the contact....so is there way to make that happen?
Sub btnAddCalendarEvent_Click
dim ContactName
dim olns
dim MyFolder
dim NumItems
dim myItems
Dim StartDateTime
Dim EndDateTime
Dim itmAppt
ContactName = Item.GetInspector.ModifiedFormPages("General").Controls("Fullname").value
Set olns = Item.Application.GetNameSpace("MAPI")
Set myfolder = Session.GetDefaultFolder(9).Folders(2)
Set itmAppt = myfolder.Items.Add("IPM.Appointment.Office Calendar Event")
itmAppt.Subject = ContactName & " - " & item.getinspector.modifiedformpages("General").controls("combobox11").text
itmAppt.Location = item.getinspector.modifiedformpages("General").controls("combobox12").text
StartDateTime = item.getinspector.modifiedformpages("General").controls("OlkDateControl1").value & " " & item.getinspector.modifiedformpages("General").controls("OlkTimeControl1").value
itmAppt.Start = StartDateTime
EndDateTime = item.getinspector.modifiedformpages("General").controls("OlkDateControl2").value & " " & item.getinspector.modifiedformpages("General").controls("OlkTimeControl2").value
itmAppt.End = EndDateTime
itmAppt.links.add item
itmappt.display
Per above post, I found way to fix it.....nothing else re this..
Not me....it comes from a technical person in Houston, Texas......PS, did you find the way to put in the second note field to a contact form where they are both visable and work separately?
E Help with macro to answer and delete calendar requests? Outlook VBA and Custom Forms 5
W Add to Calendar links - auto accept with macro Using Outlook 1
N How Can I create an Outlook Macro to import calendar? Outlook VBA and Custom Forms 1
T Using Exchange, the calendar cannot be synchronized. Using Outlook 3
B Sync Google Calendar with Outlook Using Outlook 5
G Forms error on iCloud calendar Using Outlook 18
V select default calendar Outlook VBA and Custom Forms 3
M Calendar items have a pale pink blushing Using Outlook 3
T Cannot delete a calendar Using Outlook 0
F Show events in Monthly Calendar Using Outlook 3
J Calendar events created on iPhone automatically changing default alert from 'None' to 'Time of Event' Using Outlook.com accounts in Outlook 0
A Outlook 365 New Appointments All saved to a 365 default calendar on Mac Using Outlook 0
V Unchecking my calendar and leaving shared one visible Outlook VBA and Custom Forms 1
M New Calendar Appointments: Conditionally turn off reminder and show time as free Using Outlook 14
J Cannot edit a calendar event received as an invitation Using Outlook 2
e_a_g_l_e_p_i Question about calendar Using Outlook 5
icacream Outlook 2021 - Google calendar in the peek Using Outlook 0
Fozzie Bear Shared Calendar For Scheduled Tasks Using Outlook.com accounts in Outlook 3
