Rules Fail?
I have 3 imap accounts set up in Outlook 2010. AOL my main email address, Yahoo, and Gmail.
I only use GMAIL for Youtube stuff.
Yahoo is for everything that AOL Might block out. Yall know how they are Lol.
Anyways I have rules set up when mail from GMAIL ACCOUNT comes in.. MOVE messages FROM inbox to AOL 'S INBOX. but for some reason when I go to that rule under rules its unchecked and turned off why?
I like to read everything in 1 place and not have to open the gmail triangle, then the yahoo little triangle to show all folders I'd just rather have everything moved to the AOL INBOX.
Suggestions,
Christopher
So, the gmail rule moving/copying from gmail to aol folders? I'm guessing the AOL account is not fully loaded when Outlook starts checking gmail so the rule is invalid.
Have you considered setting up forwarding at gmail.com to the aol account? That could allow you to remove the gmail account from your profile if you aren't using it to send mail... provided aol isn't filtering it. If it is, I'd probably use POP3 with gmail instead of imap.
oh, no I didnt think of that.
I just noticed, changing the rule to COPY to aol inbox then delete from original account so far isnt erroring . Odd for some reason OL has a problem with MOVING emails to another account.
Now my last concern is how come when copying emails from one folder to another it unhides the folders?
Meaning that when it copies that little triangle > shows all the folders. Its like I have all those folders shut for a reason because I have no use for them since everything is getting moved to the main folder here is an example.
HOW IT SHOULD BE:
http://i886.photobucket.com/albums/...lipStick dot com/ScreenHunter_51Dec101415.jpg
( and the only reason I have JUNK HIGHLIGHTED is to protect the emails that just came into my inbox as I took the screenshot) So I was trying to pick a folder that had nothing in it.
BUT THIS IS WHAT HAPPENS:
http://i886.photobucket.com/albums/...lipStick dot com/ScreenHunter_52Dec101415.jpg
Christopher
Is there no way to turn that off, the auto opening of folders? without having to switch to pop3?
after adding all my accounts to 2010 ( only 4) looks horrible and cluttered.
Christopher
S Outlook Classic Rules Using Outlook 3
R How to simplify rules Using Outlook 2
J Recover server side rules from OST/PST without access to the server Using Outlook 2
K Multiple Rules on Single Email Using Outlook 2
Wayne Outlook locks up when opening "Manage Rules & Alerts" Using Outlook 7
B Setting rules Using Outlook 1
A rules not working Using Outlook 2
M Rules and autoreply Using Outlook 1
O How to recover rules after switch from POP3 to IMAP Using Outlook 2
N Copies of emails from rules have wrong from: account Using Outlook 0
L Office 365 cloud based rules Using Outlook 1
CWM030 Rules disappearing in OL 2016? ( Yes, I searched before posting) Using Outlook 7
R When rules lose track of "specified folder" Using Outlook 6
I Outlook 2013 Rules - (client only) Using Outlook.com accounts in Outlook 1
A rules (flags) not working Using Outlook 7
K Lost Rules. Assistant accesses my mailbox. Disappeared Using Outlook 0
R When rules are working but invisible and unmanageable Using Outlook 2
P Transport Agent or Rules/Connectors Exchange Server Administration 1
O Rules and Alerts for New Messages BEFORE sending Using Outlook 2
D Outlook Rules Using Outlook 1
Diane Poremsky Autoaccept a Meeting Request using Rules Using Outlook 2
Gunny NFOhiway Outlook PST file and Rules Using Outlook 1
M Outlook 2016 Rules Not Working Automatically Using Outlook 5
Diane Poremsky Rules & Alerts Dialog Won't Open Using Outlook 1
P Log of Rules that ran Outlook VBA and Custom Forms 3
P Recover / Extract Rules from standalone PST file creating RWZ file Using Outlook 2
