Sub Calendar-Color Coding Issue
Brooke M
Outlook 2013 32 bit
Exchange Server 2010
I have made a sub calendar for our office to use to keep track of projects. All the projects are color coded. I have given everyone the proper permission (Reviewer), and they are able to open the shared sub folder. However, the color coding isn't showing up for them, everything is the same color.
Help Please!
For shared folders Outlook uses the master category list of the mailbox the folder belongs to. That list is stored in the mailbox' default calendar, so the users need the appropriate permissions for that default calendar. (I don't remember which permissions that are.)
I had my main calender default setting at 'folder visible', but I changed it to Reviewer, and now everyone can see the color coding!
S Leaving ActiveExplorer open for editing after Sub is done Outlook VBA and Custom Forms 0
T Cannot connect to main BT email account, sub accts okay Using Outlook 0
T Inbox Sub-Folder - Web Using Outlook 1
O Set columns for all (sub)folders Using Outlook 8
F VBA routine to write new sub routine in outlook Outlook VBA and Custom Forms 0
G how can Apply User-defined Field to all Sub Folder and Other Using Outlook 14
D Sub folders of my Inbox collapsing Using Outlook 0
C Unread email count not displaying on Inbox sub-folders Using Outlook 0
W Shared inbox sub folders not visible when moved Using Outlook 3
G Creating Contact Sub Folders Using Outlook 2
T Missing sub-contact folders (distribution lists) Using Outlook 3
D Monitor any changes to a sub-folder Outlook VBA and Custom Forms 4
G Categories - Sub Catergories Using Outlook 6
D How do I mail-enable a Public Folder Sub-folder in exchnage 2007 using shell ? Exchange Server Administration 0
R Private Sub Application_ItemSend() -Cannot make this code work in Outlook 2013 Using Outlook 0
A How to move responded emaisl automatically to sub folders in Outlook 2007 Using Outlook 0
J Incoming emails going to wrong sub-folder Using Outlook 4
T Unable to download e-mail sub account in OL 2010. No probs with Mailwasher Using Outlook 6
T Make sub folders of inbox appear BOLD when new mail arrives Using Outlook 10
D User cannot move email messages within Outlook Inbox folder and sub-folders. Using Outlook 0
C OL Sub through or by Excel Macro Call Outlook VBA and Custom Forms 1
G bcm 2007 sub folders BCM (Business Contact Manager) 1
G Forms error on iCloud calendar Using Outlook 18
V select default calendar Outlook VBA and Custom Forms 3
M Calendar items have a pale pink blushing Using Outlook 3
T Cannot delete a calendar Using Outlook 0
F Show events in Monthly Calendar Using Outlook 3
