From OL2010 Pro to OL2003 Pro
Trapper
Going backwards? !
Am installing W10 onto a new drive, went to install my Office 2010 Pro 64bit and found the DVD case was empty and I have no idea where it went.
I do have Office 2003 Pro, I only use Word, Excel and Outlook so could use that in place of 2010 as I only do basic spreadsheets and letters. Assuming W10 will accept Office 2003!
I have an OL 2010 PST file of just over 1GB (Never quite got around to deleting old stuff, just in case.... Is it possible to transfer back from 2010 to 2003 and if so how? and will a 2010 calendar transfer as well?
Thank you Diane. The link seems to be updated and now goes to Microsoft Sales, there are downloads but not it seems for Office 2010.
I do have the key code but not the program :-(
Oh, does it? I didn't test it. I know the ones at a site i used to recommend that had links to the digitalriver downloads now rolls over to sales. :(
Is it Professional or Professional Plus? I have a copy of pro plus, but the key likely won't work with it if it's for pro. I used to have the 'all in one' version here somewhere - you put in your key and it installs the correct version, but i'm not sure i can find it. It would be great if i still had it.
T Outlook 2010 Advice on syncing OL2010 Calendar and Outlook app Using Outlook 0
R OL2010 - Send to Mail Recipient going to wrong account Using Outlook 1
J Calendar search failing & wrong indexlocation showing..OL2010 Using Outlook 3
K OL2010 Button to Insert First Name Outlook VBA and Custom Forms 6
K OL2010 Button to Insert First Name Using Outlook 1
B OL2010 and install custom WYWO form Using Outlook 1
O Form cache size for OL2010 is set up to 0 Kbs, but sometimes ! Using Outlook 8
R New computer, OL2010 unable to display shared calendar appointments Exchange Server Administration 3
P OL2010 - custom form contact picture Using Outlook 0
B Updating Macro to OL2010/32bit Using Outlook 8
J OL2010 Create a new task while off line Exchange Server Administration 3
M How to skip weekends on recurring appointments - OL2010? Using Outlook 4
R OL2010 Calendar Appointment Highlighting Text issue Using Outlook 3
P migration issue from OL2003 to OL2010 with custom contact form Using Outlook 7
R OL2010; How to ALWAYS Reply/Forward using HTML? Using Outlook 1
B OL2010 - signatures while forwarding tasks or appointments Using Outlook 2
T Can't remove NEW GROUP in OL2010 Using Outlook 1
S OL2010 - choosing to not save inline images Using Outlook 1
T Reinstalled OL2010 now have 3 separate inboxes and contacts missing Using Outlook 2
T Defer Sending emails in OL2010 Using Outlook 1
G Keyboarding with HTML Email in OL2010-64bit Using Outlook 0
B how to debug in OL2010? Outlook VBA and Custom Forms 3
M OL2007 Add-in won't install on OL2010 Outlook VBA and Custom Forms 1
C Create a Ribbon for the OL2010 Explorer Outlook VBA and Custom Forms 1
H Integrating Alexa & Outlook Pro 2021 Using Outlook 2
P Recommendations Pro/Con various Stellar utilities Using Outlook 2
V Outlook 2021 Microsoft Office Pro Plus 2021 - Inexpensive Lifetime License Using Outlook 6
klpconsulting Programmatic Access Office 365 Pro Plus & RDS Using Outlook 1
D Outlook (Office) 2007 & Windows 10 Pro Using Outlook 6
S Customizing Connected Services in Office 2013 Pro Plus (O365) Using Outlook 1
O Moving OUtlook 2003 from bad XP to Win 7 Pro 64 -- URGENT! Using Outlook 8
vespinoza Upgrading to Outlook Pro Plus from Outlook/Office Standard Using Outlook 3
M Opening Word Doc's in Adobe Acrobat Pro Using Outlook 9
T BCM Install fails Both w Off. Pro 2010 Beta & on reinstall Off.Pro BCM (Business Contact Manager) 5
C Moving Business Contact Manager to Pro Plus, dropping Accounting BCM (Business Contact Manager) 1
S Can't install BCM in Ofiice Pro Trial BCM (Business Contact Manager) 4
J OL2003 (HTTP proxy) update time Exchange Server Administration 7
J OL2003 Public Folder Sync Errors w/ Exchange 2010 Exchange Server Administration 11
M Develop for OL2003 on OL2007 machine using VS2008 and VSTO? Outlook VBA and Custom Forms 1
C Cannot access macro menu in OL2003 Outlook VBA and Custom Forms 2
W OL2003 & VB6:- "Could not send the message" Outlook VBA and Custom Forms 7
C Converting users with BCM in OL2003 to RPC over HTTP BCM (Business Contact Manager) 1
