Search and delete part of a link inside HTML body message
Hanan
Exchange Server 2010
I am trying to create a rule to delete part of a link inside an HTML Email message.
The body of the message source code is:
<html><body><style></style> <p style='margin:0cm' dir=rtl bgcolor='#ffffff'><font face='Arial' size='2'> Order <a href = "priority:priform#PORDERS:pO16004270:genigar:C:\Users\hanan\WINDOWS\tabula.ini" ><span dir='ltr'>PO16004270</span></a> </font></p> </body></html>
I have to delete this part: "C:\Users\hanan\WINDOWS\"
out of it.
How can I do that. tried so many codes with no sucsses.
The method at How to Change the Font used for Outlook's RSS Feeds should work - instead of changing fonts, you'll replace that phrase with "".
NewFont = C:\Users\hanan\WINDOWS\"
OldFont = ""
That works from a rule (change PostItem to mailitem to use in a rule). To apply it to a selected message, you can use a little stub macro that calls that macro - then select the message and run this stub. It'll bring up the macro that actually does the work.
Sub StubMacro()
Dim olMail as Mailitem
Set olMail = Application.ActiveExplorer.Selection.Item(1)
   ChangeRSSFont olMail
Set OlMail = Nothing
you can change the variables names and the macro name so it makes more sense - just make sure you change all instances.
OldFont = ""
Sub StubMacro()
Thank you. Works like charm. Just a small fix for your Stub Macro, I had to set the complete pathe to the script. See below:
Sub StubMacro()
 Dim olMail As MailItem
 Project1.ThisOutlookSession.ChangeTabula olMail
 Set olMail = Nothing
T Delete Emails from search results Outlook VBA and Custom Forms 1
M How do I delete Search folders? Outlook VBA and Custom Forms 2
A Search People>press enter box disappears. Using Outlook 3
efire9207 Addressbook Search Using Outlook 4
Victor_50 Outlook 365 Quick search by period (today, yesterday, last week) completely missing in newest OL 365 Using Outlook 0
A 'search people' now asks me to 'press enter' Using Outlook 11
A Relocate Search Bar in Outlook Using Outlook 2
T Outlook365 search item listed as "potential matches" can't be opened Using Outlook 0
P Outlook 2013 search no longer works Using Outlook 2
C How to search for items in Outbox with multiple accounts? Using Outlook 20
J search doesn't find anything Using Outlook 1
C Search not accurate, but not indexing Using Outlook 9
H Outlook 2019 intermittent search results Using Outlook 0
H Search Email Header for Content Type Outlook VBA and Custom Forms 1
P Posts in Folder No Longer Group by Conversation Column After Search Using Outlook 0
O Advanced search - can I use booleans Using Outlook 3
M Something went wrong and your search couldn't be completed Using Outlook 1
L New Location for the Search Bar Using Outlook 6
