Outlook won't work
Phil52
Outlook.com (as MS Exchange)
i keep getting this error when i try to open icloud:
C:\PROGRA~2\COMMON~1\Apple\INTERN~1\APLZOD.dll
and my me.com account keeps asking for the password.
I found this but not sure how to edit the registry.
Will it also fix the problem where my email keeps asking for the password?
Fixed: iCloud doesn't work in Outlook 2007 - Outlook Tips
You don't need to edit the registry - use the registry key linked at the bottom of the page. Right click and download the file then double click to run it - you'll need to Ok 3 or 4 dialogs. The file should have the .reg extension, if your browser (firefox and possibly others) will save it with a .txt extension, you'll need to change it to .reg.
The password problem is different. If you add an iCloud account to a 3rd party utility (such as Outlook), you need to enable 2 factor auth and use an app password when you sign in using Outlook. (Apple's implememation is a PITA frankly, especially if you have multiple apple devices or share your account with family members.)
L Outlook Office 365 client: won't remember my setting File, not to collapse ribbon Using Outlook 2
M outlook won't open! Using Outlook 1
soadfan Outlook won't send e-mail when offline Outlook VBA and Custom Forms 19
P Outlook 2016 won't Start Using Outlook 3
Diane Poremsky Outlook 2013: Control Panel Mail Won't Open Using Outlook 0
Diane Poremsky Outlook Links Won't Open In Windows 10 Using Outlook 1
L Outlook 2013 won't open MS Office attachments Using Outlook 1
T Outlook 2010 calendar won't sync with Android phone Using Outlook 3
A iPhone Contacts in Outlook won't File As First, Last Using Outlook 0
J Outlook won't open. PST file busy. Using Outlook 3
P Outlook 2007 won't connect Using Outlook 6
S Outlook 2010 won't send on Windows 8 Using Outlook 2
M Outlook 2013/365 won't export 99% of my contacts to csv Using Outlook 2
B Add-in "always enabled" but Outlook 13 won't open Using Outlook 7
C Outlook 2010 Address Book, won't stay selected Using Outlook 5
R Emails won't come into outlook but can send Using Outlook 0
Z Outlook opens minimized, won't maximize Using Outlook 2
J Email won't send Automatically in Outlook 2010 Using Outlook 3
G Outlook 2013 won't download images Using Outlook 6
E Outlook 2013 calendar won't sync with iphone 4s Using Outlook 14
B Outlook 2010 won't preview Office attachments Using Outlook 3
B Outlook 2010 asking for password constantly, won't accept correct one Using Outlook 5
I Outlook 2003 won't send emails through one router, but will through another Using Outlook 1
A Outlook won't send emails Using Outlook 1
J links won't open from Outlook Using Outlook 1
M Outlook 2007 won't respond? Using Outlook 3
C Outlook 2010 won't use a view other than maximized Using Outlook 1
M Outlook Express won't open Using Outlook 1
B Outlook 2010 won't configure exchange account, 0kb .ost file Exchange Server Administration 5
B outlook 2007 won't play video attachments Using Outlook 3
B Outlook 2003 PST File Won't Compact Using Outlook 1
C Outlook editing won't select just one word Using Outlook 1
D outlook won't open attachments Using Outlook 1
R [outlook-users] Messages won't archive Using Outlook 5
A Outlook 11 for Mac won't print e-mail attachments Using Outlook 6
W Outlook exp. 2007 problems - won't receive new mail Using Outlook 1
J Mail read in OWA won't appear in Outlook Exchange Server Administration 1
D Outlook 2010 won't launch after installin Microsoft office 2010 service pack 1 Using Outlook 1
T Outlook 2003 with multiple explorers won't shutdown Outlook VBA and Custom Forms 2
G Data Left Behind when Migrating To Outlook from Thunderbird - Insights on the Issue Using Outlook 0
