Strange Calendar Entries
patlaw
We use Office 365. A user's calendar is attached. Any time he accepts an invitation to a meeting, it shows as "Busy" (with no other information) on his calendar. The entries are not marked confidential. He shows up in Scheduling Assistant as attending the meeting on the Tuesday 10:30 entry. Is there a security setting that enables this behavior? I seriously doubt he is manually making the changes to show Busy instead of having Outlook display the event details. I'm a user, not an administrator.
2690
Is this his own personal calendar? That is what you see if a calendar is shared with free/busy information only - for the people its shared with. The calendar owner should see the full details.
It's his personal calendar shared with the rest of the group. Thanks for the information. I'd never heard of that option before. I see it now.
So its the group that sees the above, not the actual calendar owner? Changing the permissions will fix it.
Yes, that's correct. I'm sorry if I misunderstood your question. The problem has been solved. Thank you!
A Strange Attachment Behavior Using Outlook 9
B Strange MAPI/Exchange/IMAP behaviour in OL 2016 under10.0.19044.2006 Using Outlook 0
M Outlook.com autocomplete list invaded by strange items Using Outlook.com accounts in Outlook 7
A Outlook 2016 - adding outlook.com account creates a new/strange address Using Outlook.com accounts in Outlook 18
M Outlook adds strange characters inserted into the Subject Line Using Outlook 2
E Strange Send/Receive count Using Outlook 3
F Strange problem with calendars Using Outlook 3
dolke Strange Outlook behavior when receiving emails. More info in the content... Using Outlook 7
A Two strange calender problems in Outlook 2003 ... Using Outlook 2
S Outlook 2007 Add-in strange load behavior Outlook VBA and Custom Forms 10
B strange change in Outlook 2000 forms Outlook VBA and Custom Forms 1
E Strange save request when closing Outlook 2007 Outlook VBA and Custom Forms 4
S Strange Behaviour of Explorer Object. Outlook VBA and Custom Forms 1
G Forms error on iCloud calendar Using Outlook 18
V select default calendar Outlook VBA and Custom Forms 3
M Calendar items have a pale pink blushing Using Outlook 3
T Cannot delete a calendar Using Outlook 0
F Show events in Monthly Calendar Using Outlook 3
J Calendar events created on iPhone automatically changing default alert from 'None' to 'Time of Event' Using Outlook.com accounts in Outlook 0
A Outlook 365 New Appointments All saved to a 365 default calendar on Mac Using Outlook 0
V Unchecking my calendar and leaving shared one visible Outlook VBA and Custom Forms 1
M New Calendar Appointments: Conditionally turn off reminder and show time as free Using Outlook 14
J Cannot edit a calendar event received as an invitation Using Outlook 2
