Trying to move messages between imap accounts/folders
Post number 4 has been selected as the best answer.
Cara
Outlook 2021 64 bit
I have set up a "Quick Step" to move the current message to my All Mail folder on one of my (many) Gmail accounts - this is the folder I use for my consolidated "archive." All of my email accounts are imap. The quick step sometimes seems to work, and I almost immediately see the new account/folder reflected in my message list (my view shows the account + folder) - but sometimes it does not. So I send/receive, thinking that the messages have to be synced to move, and I still see no change. This happens, sometimes, even if I manually move the message, without using the Quick Step.
What does it take to get my view of my message list to update the account and folder?
Are you moving the mail to one All Mail folder or to the All Mail folder in one account?
Did you have the all mail folder showing before you created the quick step? By default, the all mail folder is hidden (because it creates duplicates when synced as imap) and you need enable it.
to show the all mail folder:
From volume 26 Number 12 (slipstick.com)
  1. Right-click the IMAP Inbox in Outlook.
  2. Choosing IMAP folders...
  3. Click Query to load the folder list.
  4. The All Mail folder will be displayed as subscribed - select it and click the Sign Out button.
  5. Click the Query button again to reload the Folder List.
  6. Select the All Mail folder and subscribe.
  7. Close the dialog box.
  8. Right-click the [Gmail] folder and create a new folder.
  9. Call it all Mail.
The email should be synced in a few minutes.
I'm not sure what you mean, by the first question. I have multiple gmail, outlook.com, and other imap accounts. I want to move messages from any of these accounts to a specific account's All Mail folder.
I definitely already have access to and see the target All Mail folder. Here's what I see in search results, with my custom view:
Note that the red messages are highlighted via conditional formatting in the view, which should indicate which messages are already in my desired "archive" folder. If you look at the 4th message in the list, you'll see one that's archived (right account, right folder). The one immediately above it is, when I open the message and ctrl+shift+f, actually ALSO in that desired folder - but the email account column still shows the original account it was received in. In other words, the message has been moved from the Inbox on a Comcast.net account to the All Mail folder on my GMail account - but the Email Account doesn't get updated.
How can I get the view's "Email Account" folder to reflect the account that I moved the message to?
This is what I was wondering.
The email account column should show the account it was received on. Outlook data file should show the location it is currently.
Thank you, @Diane! Guess I need to explore those columns to see what more of them mean! I had no idea that one was there, and never would've guessed it was useful.
Quick follow-up question on this, @Diane Poremsky - I'm trying to use that "Outlook Data File" column in conditional formatting. My criteria is that if the email is in a specific data file (Outlook Data File contains "xxx") and specific folder (Folder = "All Mail"), it should be highlighted in red. Previously, I highlighted if the Email Account was "xxx," and it worked sometimes. Now, it never works. Is there a trick to using the Outlook Data File column in a conditional format?
C Trying to move my Business Contact Manager ver. 2003 to BCM ver. 2010 Using Outlook 3
U Recovered PST file "Cannot move item" error when trying to move e- Using Outlook 6
B Trying to Merge Gmail and POP/SMTP inboxes Using Outlook 4
W frustrating trying to change email password Using Outlook 5
e_a_g_l_e_p_i I can't believe what I am seeing when trying to install Outlook 2021 Using Outlook 9
J Outlook 2016 Trying to get Outlook 2016 to work with Office 365 Using Outlook 0
U Outlook not responding when trying to print Emails Using Outlook 6
e_a_g_l_e_p_i Trying to customize the ribbon but can't figure this one out Using Outlook 3
B Outlook 2016 Outlook crashes when trying to print certain emails Using Outlook 5
M outlook 365 trying to finish my sentences Using Outlook 2
O The page that you are trying to access cannot be loaded. Using Outlook 0
C Trying to populate an appointment ComboBox from Excel Outlook VBA and Custom Forms 2
T Outlook "A program is trying to access Outlook" Using Outlook 3
KURTiS MAXiMUS Trying to appactivate ERP window Outlook VBA and Custom Forms 16
R Trying to extract information between two symbols from outlook subject Using Outlook 2
Danie Lawson Trying to recover calendar Using Outlook 4
L Trying to open contacts pst. file in outlook 365 Using Outlook 3
L Trying to check for the absence of mail. Outlook VBA and Custom Forms 1
D Trying to repair Outlook rules Using Outlook 5
S Outlook 2010 trying to default Data file to outlook.com calendar Using Outlook 6
R Trying to sync my Outlook email on iphone Using Outlook 1
A outlook trying to keep sending Using Outlook 1
P Trying to add subject and name to an email using VB Code Using Outlook 3
B Trying to get old emails from a not working computer but having trouble. Using Outlook 6
P Outlook works, but freezes when trying to use calender v2007 (vista prof) Using Outlook 1
K A program is trying to send an e-mail message on your behalf... Using Outlook 1
P Trying to get 'Calendar Name' to appear like 'Subject' and 'Location' in event Using Outlook 0
S Trying to have a prompt to ask for text to be added to subject before sending. Using Outlook 3
A Trying to connect to exchange Exchange Server Administration 3
K Wont send or recieve now with new server keeps asking for password when trying Using Outlook 1
D Outlook "Trying to Connect" Exchange Server Administration 1
P Word experienced and error trying to open the file Using Outlook 2
S Trying to install BCM 2010 x64, getting error BCM (Business Contact Manager) 8
D Outlook 2003 - A program is trying to access e-mail addresses Outlook VBA and Custom Forms 5
S Trying to create a UPS from Outlook VBA and Custom Forms 2
T Trying to start Outlook from VBA or VBS not working. Outlook VBA and Custom Forms 4
S how to disable security message in save attachments macro "A programis trying to access e-mail addre Outlook VBA and Custom Forms 5
A Error: 3033 when trying to OpenDatabase using DAO Outlook VBA and Custom Forms 3
D Error trying to connect to database on the server BCM (Business Contact Manager) 1
D Trying to reconnect BCM databases in Outlook 2003 BCM (Business Contact Manager) 1
H Move Selected emails to Local Drive Outlook VBA and Custom Forms 0
A Outlook 365 (OutLook For Mac)Move "On My Computer" Folder Items From Old To New Mac Computer Using Outlook 4
